Wat je nodig hebt
Remove the two screws using a PH #00 Phillips head screw driver.
Place the device face down on a flat surface.
Insert one of the wide tipped, plastic opening tools into the top of the left speaker slot.
Pry the back plate open and slide the tool in a clockwise direction, moving it along the opening between the device and its back plate until you reach the power button.
Één andere persoon heeft deze handleiding voltooid.
