Ga door naar hoofdinhoud
Matsunichi MarquisPad MP977 Battery Replacement
Wat je nodig hebt
  1. Matsunichi MarquisPad MP977 Battery Replacement, Battery: stap 1, afbeelding 1 van 1
    • Remove the two screws using a Phillips #00 screwdriver.
  2. Matsunichi MarquisPad MP977 Battery Replacement: stap 2, afbeelding 1 van 3 Matsunichi MarquisPad MP977 Battery Replacement: stap 2, afbeelding 2 van 3 Matsunichi MarquisPad MP977 Battery Replacement: stap 2, afbeelding 3 van 3
    • Place the device face down on a flat surface.
    • Insert one of the wide-tipped, plastic opening tools into the top of the left speaker slot.
    • Be sure to avoid puncturing the covering of the speaker.
    • Pry the back plate open and slide the tool in a clockwise direction, moving it along the opening between the device and its back plate until you reach the power button.
  3. Matsunichi MarquisPad MP977 Battery Replacement: stap 3, afbeelding 1 van 2 Matsunichi MarquisPad MP977 Battery Replacement: stap 3, afbeelding 2 van 2
    • Insert the opening tool into the right speaker slot.
    • Pry open the back plate, and slide the tool counterclockwise along the device until you reach the charging port.
  4. Matsunichi MarquisPad MP977 Battery Replacement: stap 4, afbeelding 1 van 1
    • Remove the back plate and place it to the side.
  5. Matsunichi MarquisPad MP977 Battery Replacement: stap 5, afbeelding 1 van 2 Matsunichi MarquisPad MP977 Battery Replacement: stap 5, afbeelding 2 van 2
    • Detach the battery from the motherboard.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Evan Campbell
88 Reputatie
1 Handleiding geschreven
UMass Dartmouth, Team 4-1, Vijaybhaskar Spring 2015 Lid van UMass Dartmouth, Team 4-1, Vijaybhaskar Spring 2015
UMASSD-VIJAYBHASKAR-S15S4G1
3 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 5
Altijd: 1,535
