Ga door naar hoofdinhoud
Matsunichi M97 9 inch Screen Replacement
Wat je nodig hebt
  1. Matsunichi M97 9 inch Screen Replacement, Battery: stap 1, afbeelding 1 van 1
    • Open the micro SD cover located on the back of the device.
  2. Matsunichi M97 9 inch Screen Replacement: stap 2, afbeelding 1 van 1
    • Using the Phillips #00 screwdriver, remove the two 4mm screws next to the micro SD port.
  3. Matsunichi M97 9 inch Screen Replacement: stap 3, afbeelding 1 van 3 Matsunichi M97 9 inch Screen Replacement: stap 3, afbeelding 2 van 3 Matsunichi M97 9 inch Screen Replacement: stap 3, afbeelding 3 van 3
    • Use the iFixit opening tool to pry off the back cover of the device.
    • The volume buttons and the lock switch will come loose when the back comes off.
  4. Matsunichi M97 9 inch Screen Replacement: stap 4, afbeelding 1 van 2 Matsunichi M97 9 inch Screen Replacement: stap 4, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    Koop
    • Use a pair of tweezers to disconnect the battery from the motherboard.
  5. Matsunichi M97 9 inch Screen Replacement: stap 5, afbeelding 1 van 2 Matsunichi M97 9 inch Screen Replacement: stap 5, afbeelding 2 van 2
    • Carefully unstick the battery from the frame using the spudger.
    • Do not bend or puncture the battery during removal.
  6. Matsunichi M97 9 inch Screen Replacement, Motherboard: stap 6, afbeelding 1 van 2 Matsunichi M97 9 inch Screen Replacement, Motherboard: stap 6, afbeelding 2 van 2
    • Remove the six 2mm screws that hold the motherboard onto the case using the Phillips #00 screwdriver.
    • Use the same screwdriver to remove the single 4mm screw.
  7. Matsunichi M97 9 inch Screen Replacement: stap 7, afbeelding 1 van 2 Matsunichi M97 9 inch Screen Replacement: stap 7, afbeelding 2 van 2
    • Gently pull the display ribbon cable to unplug it from the motherboard.
  8. Matsunichi M97 9 inch Screen Replacement: stap 8, afbeelding 1 van 1
    • Use a spudger or an iFixit opening tool to lift the locking mechanism holding the camera ribbon cable.
  9. Matsunichi M97 9 inch Screen Replacement: stap 9, afbeelding 1 van 2 Matsunichi M97 9 inch Screen Replacement: stap 9, afbeelding 2 van 2
    • Lift up on the wifi antenna cable to unsnap it from the motherboard.
    • Then unhook the cable from the holding bracket.
  10. Matsunichi M97 9 inch Screen Replacement: stap 10, afbeelding 1 van 2 Matsunichi M97 9 inch Screen Replacement: stap 10, afbeelding 2 van 2
    • Use the spudger or iFixit opening tool to lift up on the locking mechanism for the digitizer ribbon cable.
    • Pull the cable from its connection.
  11. Matsunichi M97 9 inch Screen Replacement: stap 11, afbeelding 1 van 2 Matsunichi M97 9 inch Screen Replacement: stap 11, afbeelding 2 van 2
    • Use the Phillips #00 screwdriver to remove the four 4mm screws that hold the speakers in place.
  12. Matsunichi M97 9 inch Screen Replacement: stap 12, afbeelding 1 van 1
    • Pull the vibration motor out of its housing.
  13. Matsunichi M97 9 inch Screen Replacement: stap 13, afbeelding 1 van 2 Matsunichi M97 9 inch Screen Replacement: stap 13, afbeelding 2 van 2
    • Lift the motherboard off the frame.
  14. Matsunichi M97 9 inch Screen Replacement, Camera: stap 14, afbeelding 1 van 2 Matsunichi M97 9 inch Screen Replacement, Camera: stap 14, afbeelding 2 van 2
    • Remove the camera from the device.
  15. Matsunichi M97 9 inch Screen Replacement, Screen: stap 15, afbeelding 1 van 3 Matsunichi M97 9 inch Screen Replacement, Screen: stap 15, afbeelding 2 van 3 Matsunichi M97 9 inch Screen Replacement, Screen: stap 15, afbeelding 3 van 3
    • Peel off the black and the clear tape covering the display cable connection.
    • Pull the display cable to disconnect it from the display.
  16. Matsunichi M97 9 inch Screen Replacement: stap 16, afbeelding 1 van 2 Matsunichi M97 9 inch Screen Replacement: stap 16, afbeelding 2 van 2
    • Peel off the conductive tape covering the display board.
  17. Matsunichi M97 9 inch Screen Replacement: stap 17, afbeelding 1 van 2 Matsunichi M97 9 inch Screen Replacement: stap 17, afbeelding 2 van 2
    • Peel off the Kapton thermal tape from the display board.
  18. Matsunichi M97 9 inch Screen Replacement: stap 18, afbeelding 1 van 2 Matsunichi M97 9 inch Screen Replacement: stap 18, afbeelding 2 van 2
    • Peel off the grounding tape attached to the display board.
  19. Matsunichi M97 9 inch Screen Replacement: stap 19, afbeelding 1 van 2 Matsunichi M97 9 inch Screen Replacement: stap 19, afbeelding 2 van 2
    • Peel off the black tape near the wifi antenna from the frame.
    • Do not pull the tape completely off to avoid damage to the wifi antenna.
  20. Matsunichi M97 9 inch Screen Replacement: stap 20, afbeelding 1 van 2 Matsunichi M97 9 inch Screen Replacement: stap 20, afbeelding 2 van 2
    • Using the Phillips #00 screwdriver, unscrew the seven 4mm screws holding the frame to the front glass.
    • Gently lift the frame off the LCD panel
  21. Matsunichi M97 9 inch Screen Replacement: stap 21, afbeelding 1 van 1
    • Lift up the LCD panel from the glass digitizer.
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 8
Altijd: 112
