Inleiding
This repair may be necessary, as the eyes in the T-Rex can easily break or stop lighting up. In order to begin this repair, all you need is a small JIS #1 screwdriver, wire cutter, LED bulb, and a small pair of tweezers.
Wat je nodig hebt
Bijna klaar!
To reassemble your device, follow these instructions in reverse order. Use a soldering station to solder new LED onto the fresh-cut wires.
Conclusie
