Ga door naar hoofdinhoud
Master and Dynamic MW50 Charging Port Replacement
Wat je nodig hebt
  1. Master and Dynamic MW50 Charging Port Replacement, Master and Dynamic MW50 Disassembly: stap 1, afbeelding 1 van 3 Master and Dynamic MW50 Charging Port Replacement, Master and Dynamic MW50 Disassembly: stap 1, afbeelding 2 van 3 Master and Dynamic MW50 Charging Port Replacement, Master and Dynamic MW50 Disassembly: stap 1, afbeelding 3 van 3
    • Pull the cushion off of the desired side by gripping the top of the headphones and pulling the cushion off.
  2. Master and Dynamic MW50 Charging Port Replacement: stap 2, afbeelding 1 van 1
    • Remove the four 5mm screws from the earpiece with a Y1 Triwing screwdriver.
  3. Master and Dynamic MW50 Charging Port Replacement: stap 3, afbeelding 1 van 1
    • Use the Jimmy to lift up the black cover to get inside the device.
  4. Master and Dynamic MW50 Charging Port Replacement, Charging Port: stap 4, afbeelding 1 van 2 Master and Dynamic MW50 Charging Port Replacement, Charging Port: stap 4, afbeelding 2 van 2
    • Remove the two 2mm screws pictured with a JIS #00 screwdriver.
    • Gently pull the silver cover off of the ear piece.
  5. Master and Dynamic MW50 Charging Port Replacement: stap 5, afbeelding 1 van 1
    • Remove the two 2mm screws shown with a JIS #00 screwdriver.
  6. Master and Dynamic MW50 Charging Port Replacement: stap 6, afbeelding 1 van 1
    • Lift up the mother board with the attached charging port to see the soldering points. You must desolder these points in order to detach (and re-attach) the charging port.
Conclusie
Tyler Guffey
208 Reputatie
2 handleidingen geschreven
Cal Poly, Team S1-G4, White Winter 2019 Lid van Cal Poly, Team S1-G4, White Winter 2019
CPSU-WHITE-W19S1G4
4 Leden
12 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 2
Altijd: 297
