Inleiding
Before starting this guide, you should be able to follow the instructions without any prior knowledge with electronics. However, if you do not have experience with any wiring, follow these steps exactly. The device should be off and there is little chance of any electricity going through the system, but be sure to take all the precautions set out in this guide. While not necessary, you may use a pair of thin gloves while replacing this guide, however using the gloves will make replacing the battery slightly harder.
Wat je nodig hebt
Remove two of the three screws shown on the bottom of the device.
Begin removing the last screw, but leave it partially in the socket to remove the bottom cover easier.
To reassemble your device, follow these instructions in reverse order starting with Step 12.
