Inleiding
Follow this guide to replace the Folded Motion Tweeter found inside your MartinLogan Motion 4i Speaker.
You must have the back cover removed from the Speaker to start repairs. If you have already removed the back cover, please skip to step 7.
You will also need a Soldering iron to replace the Tweeter. Please be responsible with this tool and learn how to properly handle it before continuing. Unfortunately, we as students do not have access to a working soldering iron for this project so we are limited in what example pictures we can list.
Wat je nodig hebt
Remove the speaker grill from the face of the speaker by using both hands to grip both ends of the speaker grill and pulling up to release the magnetic ends.
In order to access the tweeter, we must first remove the Crossover, which is highlighted in red.
Using the soldering iron, desolder the connections on both the blue and black wires.
