Ga door naar hoofdinhoud
Martian Victory Watch band Replacement
Wat je nodig hebt
  1. Martian Victory Watch band Replacement, Watch band: stap 1, afbeelding 1 van 1
    • Take the watch band removal tool and insert it in the small slit between watch bezel and the band, resting up against the bezel.
  2. Martian Victory Watch band Replacement: stap 2, afbeelding 1 van 1
    • Press down of the shaft that holds the band on, while simultaneously dragging the tip of the tool back towards the band in order to compress the spring bar that holds the band on.
    • Drag the tip of the tool away from the bezel while still pressing down in order to remove the shaft from the bezel.
    • The spring shaft may decompress once its out of the bezel and try to shoot away.
  3. Martian Victory Watch band Replacement: stap 3, afbeelding 1 van 1
    • Repeat these steps on the other side of the band to completely remove the band, ready for cleaning or replacement.
Conclusie
Dominic Coffey
243 Reputatie
2 handleidingen geschreven
IUPUI, Team 3-3, Baechle Fall 2016 Lid van IUPUI, Team 3-3, Baechle Fall 2016
IUPUI-BAECHLE-F16S3G3
4 Leden
8 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 14
Altijd: 295
