Inleiding
The removal of the band is required if you wish to perform a thorough cleaning of the bezel, or if you need to replace the band itself.
Wat je nodig hebt
Take the watch band removal tool and insert it in the small slit between watch bezel and the band, resting up against the bezel.
Press down of the shaft that holds the band on, while simultaneously dragging the tip of the tool back towards the band in order to compress the spring bar that holds the band on.
Drag the tip of the tool away from the bezel while still pressing down in order to remove the shaft from the bezel.
