Ga door naar hoofdinhoud
Marshall Woburn Subwoofer Replacement
Wat je nodig hebt
  1. Marshall Woburn Subwoofer Replacement, Back Panel: stap 1, afbeelding 1 van 2 Marshall Woburn Subwoofer Replacement, Back Panel: stap 1, afbeelding 2 van 2
    • Before starting, unplug the speaker from any power source. After unplugging the device, wait around 10 minutes before starting to let the capacitor fully discharge.
    • On a flat surface, orient the device so that the front grille is facing downward.
    • Using a Phillips #1 screwdriver, remove the ten outer 28.6 mm screws marked in red.
    • Remove the eight inner 28.6 mm screws with the Phillips #1 screwdriver.
  2. Marshall Woburn Subwoofer Replacement: stap 2, afbeelding 1 van 2 Marshall Woburn Subwoofer Replacement: stap 2, afbeelding 2 van 2
    • Lift the back input board slightly above the back panel.
    • Rotate the input board so that you can slide it into the hole in the back panel that it came from.
    • Fully slide the input board through the back panel and set it down gently inside the speaker.
  3. Marshall Woburn Subwoofer Replacement: stap 3, afbeelding 1 van 1
    • Grab the panel by the large hole and lift one side until you can fit your hand under.
    • Use your hand to fully remove the back panel from the rest of the frame.
  4. Marshall Woburn Subwoofer Replacement, I/O Board: stap 4, afbeelding 1 van 1
    • Disconnect the 5 wires circled in red from the back input board.
    • There may be a little resistance when pulling on the wires, but it should not require excessive force.
  5. Marshall Woburn Subwoofer Replacement: stap 5, afbeelding 1 van 2 Marshall Woburn Subwoofer Replacement: stap 5, afbeelding 2 van 2
    • Remove the two 12.7 mm screws marked in red from the front of the back input panel with a Phillips #1 screwdriver.
    • Remove the power input from the back side of the panel.
  6. Marshall Woburn Subwoofer Replacement: stap 6, afbeelding 1 van 1
    • Completely remove the I/O board and the attached plate.
  7. Marshall Woburn Subwoofer Replacement, Subwoofer: stap 7, afbeelding 1 van 1
    • Using a Phillips #1 screwdriver, remove the eight 15.8 mm screws attaching the subwoofers to the frame.
  8. Marshall Woburn Subwoofer Replacement: stap 8, afbeelding 1 van 1
    • Lift each subwoofer up and out of the case and remove them together. This may require some foce.
Conclusie
Kenneth
169 Reputatie
2 handleidingen geschreven
UMass Dartmouth, Team 2-4, Gulbrandsen Fall 2023 Lid van UMass Dartmouth, Team 2-4, Gulbrandsen Fall 2023
UMASSD-GULBRANDSEN-F23S2G4
3 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 37
Altijd: 210
