Inleiding
The main button on top of the Marshall Emberton speaker is used to navigate between tracks and also the volume. This guide provides detailed instructions on how to replace the main button on the Emberton Bluetooth speaker.
With constant pressure on the button, it may eventually wear out and stop working. Replacing the button is very simple and only requires a TR-9 screwdriver.
Wat je nodig hebt
Remove the rubber casing from the speaker by peeling it off using your nails.
