Ga door naar hoofdinhoud
Manual recalibration
  1. Manual recalibration, Manual recalibration: stap 1, afbeelding 1 van 1
    • Open the Thrustmaster Control panel application and set the angle to 1080°
    • If you are using PlayStation, manually set rotation angle to 1080°
    • Unplug and re-plug T-GT II to USB port.
    • Wait for auto-calibration to finish
  2. Manual recalibration, Steer the wheel all the way to the left: stap 3, afbeelding 1 van 1
    • Keep turning the wheel until you reach a physical stop
  3. Manual recalibration, Steer the wheel all the way to the right: stap 4, afbeelding 1 van 1
  4. Manual recalibration, Center your wheel: stap 5, afbeelding 1 van 1
    • Perfectly center your wheel.
    • Keep in mind that rotation is set to 1080°.
  5. Manual recalibration, Press the indicated buttons: stap 6, afbeelding 1 van 1
    • Press SHARE + OPTIONS + MODE buttons at the same time.
    • LED will flash if successful.
    • If you are using a different wheel, then a button combination will be different. You can find button combination list here.
Eindstreep
Formica Fusca
2.595 Reputatie
15 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 25
Altijd: 331
