Inleiding
This guide will show you the necessary steps to locate and replace the LED light. It shows how to remove the battery and the outer casing in order to locate the LED light on the drill.
Wat je nodig hebt
Hold the drill upright.
Place your finger on the white battery-release button.
Hold the drill upright with the back panel facing you.
Unscrew the two 18 mm screws from the back panel using a Phillips PH2 screwdriver.
Use the pointed end of a plastic spudger to push the LED out of the drill.
