Inleiding
This guide will show you the necessary steps to locate and replace the gear select switch. It shows how to remove the battery and the outer casing in order to locate the gear select switch.
Wat je nodig hebt
Hold the drill upright with the back panel facing you.
Unscrew the two 18 mm screws from the back panel using a Phillips PH2 screwdriver.
Pull the silver metal clip located towards the back of drill away from the motor assembly.
3 andere personen hebben deze handleiding voltooid.
