Ga door naar hoofdinhoud
Makita XPH01 Forward/Reverse Switch Replacement
Wat je nodig hebt
  1. Makita XPH01 Forward/Reverse Switch Replacement, Battery: stap 1, afbeelding 1 van 1
    • Hold the drill upright.
    • Place your finger on the white battery-release button.
  2. Makita XPH01 Forward/Reverse Switch Replacement: stap 2, afbeelding 1 van 1
    • Press and hold the white release button located on the front of the battery.
  3. Makita XPH01 Forward/Reverse Switch Replacement: stap 3, afbeelding 1 van 1
    • Slide the battery forward while pressing down on the white battery-release button.
  4. Makita XPH01 Forward/Reverse Switch Replacement, Outer Casing: stap 4, afbeelding 1 van 2 Makita XPH01 Forward/Reverse Switch Replacement, Outer Casing: stap 4, afbeelding 2 van 2
    • Hold the drill upright with the back panel facing you.
    • Unscrew the two 18 mm screws from the back panel using a Phillips PH2 screwdriver.
  5. Makita XPH01 Forward/Reverse Switch Replacement: stap 5, afbeelding 1 van 1
    • Apply slight pressure to the sides of the backplate and pull away from the drill.
  6. Makita XPH01 Forward/Reverse Switch Replacement: stap 6, afbeelding 1 van 2 Makita XPH01 Forward/Reverse Switch Replacement: stap 6, afbeelding 2 van 2
    • Unscrew the nine 18 mm screws from the outer casing using a Phillips PH2 screwdriver.
  7. Makita XPH01 Forward/Reverse Switch Replacement: stap 7, afbeelding 1 van 2 Makita XPH01 Forward/Reverse Switch Replacement: stap 7, afbeelding 2 van 2
    • Apply slight pressure to the sides of the outer casing and pull away from the drill.
  8. Makita XPH01 Forward/Reverse Switch Replacement, Forward/Reverse Switch: stap 8, afbeelding 1 van 1
    • Pull the black trigger assembly away from the drill.
  9. Makita XPH01 Forward/Reverse Switch Replacement: stap 9, afbeelding 1 van 2 Makita XPH01 Forward/Reverse Switch Replacement: stap 9, afbeelding 2 van 2
    • Grab onto the forward/reverse switch.
    • Gently pull the forward/reverse switch to separate it from the trigger assembly.
Conclusie
Eric Herwatt
984 Reputatie
7 handleidingen geschreven
Cal Poly, Team 15-4, Livingston Fall 2016 Lid van Cal Poly, Team 15-4, Livingston Fall 2016
CPSU-LIVINGSTON-F16S15G4
4 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 46
Altijd: 5,948
