Inleiding
This guide will show you the necessary steps to locate and replace the forward/reverse switch. It shows how to remove the battery and the outer casing in order to locate the forward/reverse switch of the drill.
Wat je nodig hebt
Hold the drill upright.
Place your finger on the white battery-release button.
Hold the drill upright with the back panel facing you.
Unscrew the two 18 mm screws from the back panel using a Phillips PH2 screwdriver.
Pull the silver metal clip located towards the back of the motor assembly away from the drill.
Één andere persoon heeft deze handleiding voltooid.
