Ga door naar hoofdinhoud
Maisto Rock Crawler Remote Circuit Board Replacement
Wat je nodig hebt
  1. Maisto Rock Crawler Remote Circuit Board Replacement, Remote Circuit Board: stap 1, afbeelding 1 van 1
    • Remove the batteries before doing anything.
    • Use the driver and bit J1 to remove the five 9.5mm Philips screws holding the remote together.
  2. Maisto Rock Crawler Remote Circuit Board Replacement: stap 2, afbeelding 1 van 1
    • Take off the half of the remote that had the screw heads facing up.
  3. Maisto Rock Crawler Remote Circuit Board Replacement: stap 3, afbeelding 1 van 1
    • Slide out the circuit board.
    • Use the soldering iron to desolder the 3 wires.
Conclusie
5 andere personen hebben deze handleiding voltooid.
kevin
874 Reputatie
6 handleidingen geschreven
USF Tampa, Team 1-2, Sullivan Spring 2016 Lid van USF Tampa, Team 1-2, Sullivan Spring 2016
USFT-SULLIVAN-S16S1G2
3 Leden
5 opmerkingen
Can you show the wheel controller mechanism. I can see 3 contacts on mine but I think mine is missing something that would bring the contacts together as you turn the wheel to steer left and right. Thanks.
Ferdinand Fong - Antwoord
the triger is broken to drive the truck
joey heller - Antwoord
Somebody have the remote control for
Theodore Brock - Antwoord
I have a 1970 R/T charger RC car, 2.4GHz, I changed it up fully, but the pairing light wont come on. But I can show the lights,the control power is good.what is wrong can anybody help me find the problem and fix it.
Keith Pryor - Antwoord
How to pair new controller ?
Karel Říha - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 30
Altijd: 4,607
