Ga door naar hoofdinhoud
Magic Bullet NutriBullet Power Cord Replacement
Wat je nodig hebt
  1. Magic Bullet NutriBullet Power Cord Replacement, Power Cord: stap 1, afbeelding 1 van 2 Magic Bullet NutriBullet Power Cord Replacement, Power Cord: stap 1, afbeelding 2 van 2
    • Before beginning, make sure the device is unplugged.
    • With a Phillips head #2 screwdriver, begin unscrewing the four 10mm screws located on the bottom of the power base.
    It would be better to switch these points around because if someone begins unscrewing the screws and the device is plugged in, who knows what might happen. It's better to put the warning first instead of second.
    I would correct the first line to read, "With a Phillips head #2 screwdriver, begin unscrewing the four 10mm screws located on the bottom of the power base."
    Jonathan Fernandez - Antwoord
  2. Magic Bullet NutriBullet Power Cord Replacement: stap 2, afbeelding 1 van 1
    • Once the screws are removed, pull the plastic base up gently.
    • Once the plastic base is removed, there is a fan located in the center of the powerbase. Make sure the cord does not get caught or frayed by the fan.
    "Once the screws are removed, pull the plastic base up using slight tension as you pull."
    I will leave the second line as it is
  3. Magic Bullet NutriBullet Power Cord Replacement: stap 3, afbeelding 1 van 1
    • Gently lift the power cord from its side slot and place it to the side.
    "Gently lift the power cord from its slot and place it to the side."
    Hi I just want to know where I can buy the plastic little fan of the nutribullet?
    Jose Antonio Tolentino - Antwoord
  4. Magic Bullet NutriBullet Power Cord Replacement: stap 4, afbeelding 1 van 2 Magic Bullet NutriBullet Power Cord Replacement: stap 4, afbeelding 2 van 2
    • With the Phillips head #2 screwdriver, remove the two 10mm screws that secure the white bracket.
    • The white safety bracket holds the cord down. After removing it, the cord will be free.
    "With the Phillips head #2 screwdriver, remove the two 10mm screws that secure the white bracket."
    (The white safety bracket holds the cord down) After removing it, the cord will be free.
  5. Magic Bullet NutriBullet Power Cord Replacement: stap 5, afbeelding 1 van 1
    • After removing the gray base and silver casing, the wires will now be free and you will have easy access to them.
    • Gently pull out the two plastic covers at the end of the wires.
    Now the wires will be free.
    Locate the end of the wires and gently pull the two plastic covers off.
  6. Magic Bullet NutriBullet Power Cord Replacement: stap 6, afbeelding 1 van 1
    • Use tape or clamps to hold the wires together for an easy soldering experience.
    • Using a soldering iron, solder your new wire to the red wire.
    Using tape or clamps to hold the wires together will allow for an easy soldering experience.
    Line 2= as it is
Conclusie
Since this guide replacement requires cutting wires, if you want to reassemble this device, you must first re-solder new wires before following the steps backwards to reassemble the device.
3 andere personen hebben deze handleiding voltooid.
Geary Yu
1.208 Reputatie
3 handleidingen geschreven
Cal Poly, Team 19-8, Maness Winter 2015 Lid van Cal Poly, Team 19-8, Maness Winter 2015
CPSU-MANESS-W15S19G8
4 Leden
10 handleidingen geschreven
6 opmerkingen
where am I going to be the magic bullet repair
Or
there a service center here in the philippines?
Thank u.
florentinokarenjoy24 - Antwoord
Is there a service centre in Singapore?
I just bought the gadget in Melbourne (from Harvey Norman Nunawarding) last week. We used it yesterday but after one round of spinning, gadget went dead.
What could go round and to fix it at home?
Michael Lee - Antwoord
Can I plug the Magic Bullet in 220v?
Sovelita Tenerife - Antwoord
Where can I get a replacement cable from?
victoria hatton - Antwoord
Any recommendations on where to get the replacement power cord?
Patrick Donoghue - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 21
Afgelopen 30 dagen: 75
Altijd: 14,915
