Ga door naar hoofdinhoud
Magic Bullet NutriBullet Activator Replacement
Wat je nodig hebt
    1. Magic Bullet NutriBullet Activator Replacement, Curve Base: stap 1, afbeelding 1 van 1
      • Unplug the device from the wall and turn the powerbase upside down.
      Vraag FixBot
      Voeg opmerking toe
    2. Magic Bullet NutriBullet Activator Replacement: stap 2, afbeelding 1 van 2 Magic Bullet NutriBullet Activator Replacement: stap 2, afbeelding 2 van 2
      • Use a #2 Phillips Head Screwdriver to unscrew the four 10 mm screws located on the bottom of the power base.
      Vraag FixBot
      Voeg opmerking toe
    3. Magic Bullet NutriBullet Activator Replacement: stap 3, afbeelding 1 van 1
      • Use slight tension to remove the plastic base from the NutriBullet once all of the screws are removed.
      • When reassembling, note the fan located in the center of the powerbase. Make sure the cord does not get caught or frayed by the fan.
      Vraag FixBot
      Voeg opmerking toe
    4. Magic Bullet NutriBullet Activator Replacement: stap 4, afbeelding 1 van 1
      • Lift the power cord to remove it from the side slot on the curved base.
      Vraag FixBot
      Voeg opmerking toe
    5. Magic Bullet NutriBullet Activator Replacement: stap 5, afbeelding 1 van 2 Magic Bullet NutriBullet Activator Replacement: stap 5, afbeelding 2 van 2
      • Use a #2 Phillips Head Screwdriver to remove the two 10 mm screws that secure the white bracket down.
      • The white safety bracket holds the cord down. After removing it, the cord will be loosened.
      Vraag FixBot
      Voeg opmerking toe
    6. Magic Bullet NutriBullet Activator Replacement: stap 6, afbeelding 1 van 1
      • Use a #2 Phillips Head Screwdriver to remove the three 10mm screws that keep the base in place.
      Vraag FixBot
      Voeg opmerking toe
    7. Magic Bullet NutriBullet Activator Replacement: stap 7, afbeelding 1 van 1
      • Use slight tension to remove the curved base by lifting it upward off of the outside casing.
      Vraag FixBot
      Voeg opmerking toe
    1. Magic Bullet NutriBullet Activator Replacement, Outside Casing: stap 8, afbeelding 1 van 1
      • Wiggle the outside casing upward until it separates from the powerbase.
      • Hold the ring at the bottom of the powerbase to receive a better grip.
      Vraag FixBot
      Voeg opmerking toe
    1. Magic Bullet NutriBullet Activator Replacement, Rubber Covers: stap 9, afbeelding 1 van 1
      Gereedschap gebruikt in deze stap:
      • Place the NutriBullet powerbase on the table so that the three rubber screw covers are visible along the bottom of the well. Remove the covers using either tweezers or your fingers.
      Vraag FixBot
      Voeg opmerking toe
    2. Magic Bullet NutriBullet Activator Replacement, Top Screws: stap 10, afbeelding 1 van 1
      • Remove the three 15mm screws with the Philips Head 2 Screwdriver.
      Vraag FixBot
      Voeg opmerking toe
    3. Magic Bullet NutriBullet Activator Replacement: stap 11, afbeelding 1 van 1
      • Turn the NutriBullet powerbase upside down and remove the plastic casing by lifting it up. You may have to wiggle the casing in order to break away any hardened material.
      Vraag FixBot
      Voeg opmerking toe
    4. Magic Bullet NutriBullet Activator Replacement: stap 12, afbeelding 1 van 1
      • Determine which activator(s) fail to work by applying pressure to them. Then, remove the two 15mm screws that hold the activators in place by using the Philips Head 2 screwdriver.
      • Only two of the three activator tabs have green micro switches that actually turn on the motor. Use a circuit tester on the power chord and press the two micro switches simultaneously to see if they complete the circuit. If not, one or both need to be replaced.
      Vraag FixBot
      Voeg opmerking toe
    5. Magic Bullet NutriBullet Activator Replacement: stap 13, afbeelding 1 van 3 Magic Bullet NutriBullet Activator Replacement: stap 13, afbeelding 2 van 3 Magic Bullet NutriBullet Activator Replacement: stap 13, afbeelding 3 van 3
      • Using slight tension, pull the loose activator from the slot.
      • The white plastic activator should fall out and they can now be replaced.
      Vraag FixBot
      Voeg opmerking toe
    6. Magic Bullet NutriBullet Activator Replacement, Repairing internal switches: stap 14, afbeelding 1 van 1
      • Open up the green switch. The metal tab and black button will fall out. Fiddle around with the metal switch on the inside to snap it back into place and then reassemble carefully. It should make a clicking noise.
      Vraag FixBot
      Voeg opmerking toe
      • Before reassembling, you should clean up any material that has accumulated on the various parts. Be sure to keep water away from the motor, switches and other electrical components.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
62 andere personen hebben deze handleiding voltooid.
Angela Wong
1.177 Reputatie
3 handleidingen geschreven
Cal Poly, Team 19-8, Maness Winter 2015 Lid van Cal Poly, Team 19-8, Maness Winter 2015
CPSU-MANESS-W15S19G8
4 Leden
63 handleidingen geschreven
47Gids Commentaar
Seems to be almost complete info, however, where and how do I get the replacement parts?
Thank you!
Love&Peace!
Glow
Glow Wo - Antwoord Deel
Could you please let me know where I might be able to obtain replacement activators? Mind broke when cleaning the machine.
Ron - Antwoord Deel
Thank you. I would have went nuts looking for the screw under the rubber pieces. Would have probably destroyed the whole machine.
Joe Bailey - Antwoord Deel
Thanks for the demonstration!
D S Jones - Antwoord Deel
Perfect! Nice little machine that can still be serviced, unlike most of what is made today.
cward6681 - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 12
Afgelopen 7 dagen: 112
Afgelopen 30 dagen: 527
Altijd: 99,195
