Inleiding
This guide will show you how to remove and replace the battery inside your Magellan Roadmate 5250T-LM. It would be helpful to know how to solder before attempting this replacement. To remove the battery you must desolder it from the motherboard. After this, you will need to solder your new battery back on to the motherboard.
Wat je nodig hebt
Remove all four 5 mm screws from the back of the device using a Phillips Head screwdriver size 000.
3 andere personen hebben deze handleiding voltooid.
