Inleiding
It is recommended to have had some experience soldering before attempting this replacement.
Wat je nodig hebt
Place the device face down on a flat surface.
Remove the four 5mm screws at each corner using a #000 Phillips head screwdriver.
Lay the back panel on a flat surface with the battery, motherboard, and speaker facing up.
Use a plastic opening tool to gently pull the battery away from the back panel in order to remove the adhesive that helps the battery stick to the panel.
Using the soldering iron, carefully desolder the two wires connected to the speaker.
The motherboard should now be separated from both the battery and the speaker.
Één andere persoon heeft deze handleiding voltooid.
Één opmerking
Is the hard drive solded to the motherboard as a chip? Do someone have the pinout/things-in-the-diagram of the mother board?
