Ga door naar hoofdinhoud
Magellan RoadMate 5236T-LM Display Screen Replacement
Wat je nodig hebt
  1. Magellan RoadMate 5236T-LM Display Screen Replacement, Back Cover: stap 1, afbeelding 1 van 3 Magellan RoadMate 5236T-LM Display Screen Replacement, Back Cover: stap 1, afbeelding 2 van 3 Magellan RoadMate 5236T-LM Display Screen Replacement, Back Cover: stap 1, afbeelding 3 van 3
    • Place the device face down on a flat surface.
    • Remove the four 5mm screws at each corner using a #000 Phillips head screwdriver.
  2. Magellan RoadMate 5236T-LM Display Screen Replacement: stap 2, afbeelding 1 van 3 Magellan RoadMate 5236T-LM Display Screen Replacement: stap 2, afbeelding 2 van 3 Magellan RoadMate 5236T-LM Display Screen Replacement: stap 2, afbeelding 3 van 3
    • Gently wedge a plastic opening tool into the seam along the side of the device.
    • Slide the tool along the seam to pry apart the front and back covers.
  3. Magellan RoadMate 5236T-LM Display Screen Replacement: stap 3, afbeelding 1 van 2 Magellan RoadMate 5236T-LM Display Screen Replacement: stap 3, afbeelding 2 van 2
    • A ribbon cable attaches the display screen and the motherboard via a ZIF connector. Remove the tape covering where the ZIF connector connects to the mother board.
    • Use tweezers to disconnect the ZIF connector from the motherboard.
    • The ZIF connector may disconnect itself from the motherboard when removing the tape.
  4. Magellan RoadMate 5236T-LM Display Screen Replacement, Display Screen: stap 4, afbeelding 1 van 3 Magellan RoadMate 5236T-LM Display Screen Replacement, Display Screen: stap 4, afbeelding 2 van 3 Magellan RoadMate 5236T-LM Display Screen Replacement, Display Screen: stap 4, afbeelding 3 van 3
    • Place the front panel on a flat surface, screen side down.
    • Using a plastic opening tool, apply light lifting pressure to each of the 6 casing clips to release the screen from the plastic casing.
Conclusie
Megan Scribner
315 Reputatie
2 handleidingen geschreven
UMass Dartmouth, Team 4-7, Catania Fall 2016 Lid van UMass Dartmouth, Team 4-7, Catania Fall 2016
UMASSD-CATANIA-F16S4G7
3 Leden
5 handleidingen geschreven
Één opmerking
This would have been even a GREATER POST if, would have included the part number for the replacement screen,
But,
Just good information as to how to remove the damaged screen.
1975PINTOBOBSTER
1975PINTOBOBSTER - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 3
Altijd: 559
