Ga door naar hoofdinhoud
Magellan RoadMate 5120-LMTX Battery Replacement
Wat je nodig hebt
  1. Magellan RoadMate 5120-LMTX Battery Replacement, Back Cover: stap 1, afbeelding 1 van 3 Magellan RoadMate 5120-LMTX Battery Replacement, Back Cover: stap 1, afbeelding 2 van 3 Magellan RoadMate 5120-LMTX Battery Replacement, Back Cover: stap 1, afbeelding 3 van 3
    • Power off the Magellan RoadMate before beginning.
    • Remove the six 5mm Phillips #00 screws from the back of device.
  2. Magellan RoadMate 5120-LMTX Battery Replacement: stap 2, afbeelding 1 van 3 Magellan RoadMate 5120-LMTX Battery Replacement: stap 2, afbeelding 2 van 3 Magellan RoadMate 5120-LMTX Battery Replacement: stap 2, afbeelding 3 van 3
    • Pry back cover off with a plastic opening tool just enough to see where the speaker is attached to the motherboard.
    • Do not fully open the back cover or you risk damaging the speaker wire.
    • Use a spudger to disconnect the speaker connection from the motherboard.
  3. Magellan RoadMate 5120-LMTX Battery Replacement, Battery: stap 3, afbeelding 1 van 2 Magellan RoadMate 5120-LMTX Battery Replacement, Battery: stap 3, afbeelding 2 van 2
    • Run the tip of a spudger between the battery and the housing to loosen the double-sided tape holding the battery in.
    • Still using the spudger tool, pry the battery from the housing.
    • If you damage the tape while trying to remove the battery, you can replace it with any double-sided tape.
  4. Magellan RoadMate 5120-LMTX Battery Replacement: stap 4, afbeelding 1 van 3 Magellan RoadMate 5120-LMTX Battery Replacement: stap 4, afbeelding 2 van 3 Magellan RoadMate 5120-LMTX Battery Replacement: stap 4, afbeelding 3 van 3
    • Pull the edge of the tape up to remove the tape that holds the battery wire to the motherboard.
    • There is a clear rectangular adhesive strip that also needs to be removed with the pointy end of a spudger.
    • Slowly pull the connection from the motherboard.
    • Do not pull too hard or you will risk damaging the wires.
Conclusie
Steven Prout
231 Reputatie
2 handleidingen geschreven
IUPUI, Team 4-4, Wilson Fall 2016 Lid van IUPUI, Team 4-4, Wilson Fall 2016
IUPUI-WILSON-F16S4G4
4 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 9
Altijd: 480
