Ga door naar hoofdinhoud
Magellan RoadMate 2120T-LM Motherboard Replacement
Wat je nodig hebt
  1. Magellan RoadMate 2120T-LM Motherboard Replacement, Battery: stap 1, afbeelding 1 van 3 Magellan RoadMate 2120T-LM Motherboard Replacement, Battery: stap 1, afbeelding 2 van 3 Magellan RoadMate 2120T-LM Motherboard Replacement, Battery: stap 1, afbeelding 3 van 3
    • Turn the GPS over on its backside and remove the six 3 mm Phillips #1 screws.
  2. Magellan RoadMate 2120T-LM Motherboard Replacement: stap 2, afbeelding 1 van 2 Magellan RoadMate 2120T-LM Motherboard Replacement: stap 2, afbeelding 2 van 2
    • Pry up on back panel with black spudger
  3. Magellan RoadMate 2120T-LM Motherboard Replacement: stap 3, afbeelding 1 van 1
    • Disconnect battery and speaker cables from the motherboard at indicated places.
  4. Magellan RoadMate 2120T-LM Motherboard Replacement: stap 4, afbeelding 1 van 1
    • Use a spudger to remove the battery from the back panel.
    • If at all possible, please try to use a regular nylon spudger before resorting to a metal spudger. Metal spudgers are much sharper, and have the potential to accidentally pierce the battery.
    • There is a strong adhesive holding the battery to the back panel.
    • This step is not a prerequisite for replacement of other components.
  5. Magellan RoadMate 2120T-LM Motherboard Replacement, Motherboard: stap 5, afbeelding 1 van 1
    • Remove the four 3 mm Phillips #1 screws from the motherboard.
    • In the picture three out of four screws have already been removed.
  6. Magellan RoadMate 2120T-LM Motherboard Replacement: stap 6, afbeelding 1 van 2 Magellan RoadMate 2120T-LM Motherboard Replacement: stap 6, afbeelding 2 van 2
    • Remove black tape covering connection ribbon for touch-screen
  7. Magellan RoadMate 2120T-LM Motherboard Replacement: stap 7, afbeelding 1 van 3 Magellan RoadMate 2120T-LM Motherboard Replacement: stap 7, afbeelding 2 van 3 Magellan RoadMate 2120T-LM Motherboard Replacement: stap 7, afbeelding 3 van 3
    • Pull up on the brown tab holding down the ribbon.
    • In this picture the brown tab has already been lifted.
    • Lift up on the motherboard and remove it from device.
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 8
Altijd: 215
