Inleiding
This guide will break down the steps on how to remove the speaker from the device.
Wat je nodig hebt
Place the GPS with the screen facing down.
Use the black spudger to break the seal between the adhesive and battery. Use the same spudger to continue to pry the battery from the backing
After the back has been removed, locate each of the screws securing the speaker to the inside of the back cover.
Use a Phillips #0 screwdriver to remove the two 3.8mm Phillips #0 screws.
