Ga door naar hoofdinhoud
Magellan RoadMate 1440 Power Switch Replacement
Wat je nodig hebt
  1. Magellan RoadMate 1440 Power Switch Replacement, Magellan RoadMate 1440 Back Cover Disassembly: stap 1, afbeelding 1 van 1
    • Place the GPS with the screen facing down.
  2. Magellan RoadMate 1440 Power Switch Replacement: stap 2, afbeelding 1 van 2 Magellan RoadMate 1440 Power Switch Replacement: stap 2, afbeelding 2 van 2
    • Remove the four 4.2 mm screws on the back cover of the device using a Phillips #0 screwdriver.
  3. Magellan RoadMate 1440 Power Switch Replacement: stap 3, afbeelding 1 van 2 Magellan RoadMate 1440 Power Switch Replacement: stap 3, afbeelding 2 van 2
    • Remove the two 4.2mm screws at the bottom of the device using a Phillips #0 screwdriver.
  4. Magellan RoadMate 1440 Power Switch Replacement: stap 4, afbeelding 1 van 3 Magellan RoadMate 1440 Power Switch Replacement: stap 4, afbeelding 2 van 3 Magellan RoadMate 1440 Power Switch Replacement: stap 4, afbeelding 3 van 3
    • Insert the black spudger into the crease in the side of the GPS.
    • Move the end of the spudger down to break the seal between the two plastic shells.
    • Continue doing this along each side of the GPS to ensure a smooth removal.
  5. Magellan RoadMate 1440 Power Switch Replacement: stap 5, afbeelding 1 van 3 Magellan RoadMate 1440 Power Switch Replacement: stap 5, afbeelding 2 van 3 Magellan RoadMate 1440 Power Switch Replacement: stap 5, afbeelding 3 van 3
    • Fully separate the two sides of the case.
    • Remove the tape on the battery wires and the tape on the speaker wires.
  6. Magellan RoadMate 1440 Power Switch Replacement, Power Switch: stap 6, afbeelding 1 van 1
    • Once the back cover has been removed, lift the power switch from the device.
    • This is only a sliding switch, the button to power the device on is inside the unit
Conclusie
Jeremy Johnson
201 Reputatie
2 handleidingen geschreven
Clemson, Team 7-3, Benson Spring 2016 Lid van Clemson, Team 7-3, Benson Spring 2016
CLEM-BENSON-S16S7G3
4 Leden
7 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 6
Altijd: 197
