Ga door naar hoofdinhoud
Magellan RoadMate 1440 Motherboard Replacement
Wat je nodig hebt
  1. Magellan RoadMate 1440 Motherboard Replacement, Magellan RoadMate 1440 Back Cover Disassembly: stap 1, afbeelding 1 van 1
    • Place the GPS with the screen facing down.
  2. Magellan RoadMate 1440 Motherboard Replacement: stap 2, afbeelding 1 van 2 Magellan RoadMate 1440 Motherboard Replacement: stap 2, afbeelding 2 van 2
    • Remove the four 4.2 mm screws on the back cover of the device using a Phillips #0 screwdriver.
  3. Magellan RoadMate 1440 Motherboard Replacement: stap 3, afbeelding 1 van 2 Magellan RoadMate 1440 Motherboard Replacement: stap 3, afbeelding 2 van 2
    • Remove the two 4.2mm screws at the bottom of the device using a Phillips #0 screwdriver.
  4. Magellan RoadMate 1440 Motherboard Replacement: stap 4, afbeelding 1 van 3 Magellan RoadMate 1440 Motherboard Replacement: stap 4, afbeelding 2 van 3 Magellan RoadMate 1440 Motherboard Replacement: stap 4, afbeelding 3 van 3
    • Insert the black spudger into the crease in the side of the GPS.
    • Move the end of the spudger down to break the seal between the two plastic shells.
    • Continue doing this along each side of the GPS to ensure a smooth removal.
  5. Magellan RoadMate 1440 Motherboard Replacement: stap 5, afbeelding 1 van 3 Magellan RoadMate 1440 Motherboard Replacement: stap 5, afbeelding 2 van 3 Magellan RoadMate 1440 Motherboard Replacement: stap 5, afbeelding 3 van 3
    • Fully separate the two sides of the case.
    • Remove the tape on the battery wires and the tape on the speaker wires.
  6. Magellan RoadMate 1440 Motherboard Replacement, Battery: stap 6, afbeelding 1 van 2 Magellan RoadMate 1440 Motherboard Replacement, Battery: stap 6, afbeelding 2 van 2
    • Use the black spudger to break the seal between the adhesive and battery. Use the same spudger to continue to pry the battery from the backing
    • This may be a little tough to separate the battery and the adhesive
  7. Magellan RoadMate 1440 Motherboard Replacement: stap 7, afbeelding 1 van 2 Magellan RoadMate 1440 Motherboard Replacement: stap 7, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    Koop
    • Lift the battery from the device
    • Once the battery is free from the adhesive, remove the piece of tape with a pair of tweezers that is covering the connection of the battery to the motherboard.
  8. Magellan RoadMate 1440 Motherboard Replacement: stap 8, afbeelding 1 van 2 Magellan RoadMate 1440 Motherboard Replacement: stap 8, afbeelding 2 van 2
    • Unplug the battery from the mother board by pulling back the clips and pulling the wires away from the motherboards receptacle
    • It is important for your and the device's safety to remove the battery before continuing with any other part removals.
    • It is not necessary to separate the red and white wires from the battery. A replacement battery pack will come with similar wires already attached.
  9. Magellan RoadMate 1440 Motherboard Replacement, Speaker: stap 9, afbeelding 1 van 3 Magellan RoadMate 1440 Motherboard Replacement, Speaker: stap 9, afbeelding 2 van 3 Magellan RoadMate 1440 Motherboard Replacement, Speaker: stap 9, afbeelding 3 van 3
    • After the back has been removed, locate each of the screws securing the speaker to the inside of the back cover.
    • Use a Phillips #0 screwdriver to remove the two 3.8mm Phillips #0 screws.
  10. Magellan RoadMate 1440 Motherboard Replacement: stap 10, afbeelding 1 van 3 Magellan RoadMate 1440 Motherboard Replacement: stap 10, afbeelding 2 van 3 Magellan RoadMate 1440 Motherboard Replacement: stap 10, afbeelding 3 van 3
    • The speaker is connected to the motherboard by a few wires
    • Gently remove the connector from the motherboard to completely remove the speaker.
  11. Magellan RoadMate 1440 Motherboard Replacement, Power Switch: stap 11, afbeelding 1 van 1
    • Once the back cover has been removed, lift the power switch from the device.
    • This is only a sliding switch, the button to power the device on is inside the unit
  12. Magellan RoadMate 1440 Motherboard Replacement, Screen: stap 12, afbeelding 1 van 1
    • Replace the device's screen.
  13. Magellan RoadMate 1440 Motherboard Replacement: stap 13, afbeelding 1 van 3 Magellan RoadMate 1440 Motherboard Replacement: stap 13, afbeelding 2 van 3 Magellan RoadMate 1440 Motherboard Replacement: stap 13, afbeelding 3 van 3
    • It may be necessary to get help from a friend to hold the device stable while removing the screen.
    • Using two hands, pull back the tabs holding the screen in place.
    • Use a spudger to help use leverage to remove the screen, if necessary
  14. Magellan RoadMate 1440 Motherboard Replacement: stap 14, afbeelding 1 van 2 Magellan RoadMate 1440 Motherboard Replacement: stap 14, afbeelding 2 van 2
    • Raise the switch locking the ribbon cable in place.
    • Using twesers, pull the ribbon cable from the socket.
  15. Magellan RoadMate 1440 Motherboard Replacement: stap 15, afbeelding 1 van 2 Magellan RoadMate 1440 Motherboard Replacement: stap 15, afbeelding 2 van 2
    • With the ribbon cable removed, the screen is completely disconnected from the device.
    • To replace the ribbon cable, press the two tabs to push the head into the socket.
  16. Magellan RoadMate 1440 Motherboard Replacement, Motherboard: stap 16, afbeelding 1 van 1
    • Now that the screen has been removed from the motherboard, the motherboard is not connected to anything on the device.
    • Slide the ribbon cable through the opening in the circuit board in order to separate the two.
Conclusie
Miller Hall
325 Reputatie
2 handleidingen geschreven
Clemson, Team 7-3, Benson Spring 2016 Lid van Clemson, Team 7-3, Benson Spring 2016
CLEM-BENSON-S16S7G3
4 Leden
7 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 9
Altijd: 240
