Ga door naar hoofdinhoud
Inleiding
The speaker can be easily removed from the back cover.
Onderdelen
Geen onderdelen opgegeven.
  1. Remove 4 rubber caps covering each screw by inserting the screwdriver into the side of cap and prying back and forth. Please note: this is a tedious process, but be patient.
    • Remove 4 rubber caps covering each screw by inserting the screwdriver into the side of cap and prying back and forth.
    • Please note: this is a tedious process, but be patient.
  2. Remove the 4 screws holding the cover in place using a Phillips #00 screwdriver.
    • Remove the 4 screws holding the cover in place using a Phillips #00 screwdriver.
  3. Open the back cover. Lift the cover slowly and carefully; the speaker is screwed on the back cover and is connected to the circuit board.
    • Open the back cover.
    • Lift the cover slowly and carefully; the speaker is screwed on the back cover and is connected to the circuit board.
  4. Disconnect the speaker from the terminal. When reassembling, make sure that you plug the terminal in the same way.  The black wire should be on the side farthest from the battery.
    • Disconnect the speaker from the terminal.
    • When reassembling, make sure that you plug the terminal in the same way. The black wire should be on the side farthest from the battery.
  5. Once you pull off the back cover, remove the orange piece of tape on the speaker. Use a Philips #00 screwdriver to remove the 2 screws holding the speaker to the back casing. Use a Philips #00 screwdriver to remove the 2 screws holding the speaker to the back casing.
    • Once you pull off the back cover, remove the orange piece of tape on the speaker.
    • Use a Philips #00 screwdriver to remove the 2 screws holding the speaker to the back casing.
  6. Once the speaker has been unscrewed, remove the speaker from the back casing with your fingers.
    • Once the speaker has been unscrewed, remove the speaker from the back casing with your fingers.
Conclusie
Ross Light
175 Reputatie
6 handleidingen geschreven
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 0
Afgelopen 30 Dagen: 1
Altijd: 2,259
