Inleiding
A guide to accessing the GPS sensor.
Wat je nodig hebt
Remove the four rubber caps from the back by using the Phillips #00 screwdriver.
Remove the two screws on that are located on opposite sides of the board.
Carefully flip the circuit board out so you can get to the sensor easily.
Remove the tape holding the sensor to the display and take out the sensor.
Één andere persoon heeft deze handleiding voltooid.
