Ga door naar hoofdinhoud
Magellan RoadMate 1200 Back Cover Replacement
Wat je nodig hebt
  1. Magellan RoadMate 1200 Back Cover Replacement, Back Cover: stap 1, afbeelding 1 van 2 Magellan RoadMate 1200 Back Cover Replacement, Back Cover: stap 1, afbeelding 2 van 2
    • Remove the four rubber caps from the back by using the Phillips #00 screwdriver.
  2. Magellan RoadMate 1200 Back Cover Replacement: stap 2, afbeelding 1 van 1
    • Remove the four screws holding the cover in place by using the Phillips #00 screwdriver.
  3. Magellan RoadMate 1200 Back Cover Replacement: stap 3, afbeelding 1 van 2 Magellan RoadMate 1200 Back Cover Replacement: stap 3, afbeelding 2 van 2
    • Remove the back cover from the device by separating the back cover along its seam.
    • Slowly lift the cover—the speaker is screwed onto the back cover and is connected to the circuit board.
  4. Magellan RoadMate 1200 Back Cover Replacement: stap 4, afbeelding 1 van 2 Magellan RoadMate 1200 Back Cover Replacement: stap 4, afbeelding 2 van 2
    • Pull the speaker cord, horizontally, by its base, away from the motherboard.
    • When reassembling, make sure that you plug the terminal in the same way. The black wire should be on the side farthest from the battery.
Conclusie
Ross Light
217 Reputatie
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 12
Altijd: 3,479
