Inleiding
Use this as a guide to remove the motherboard so you can access the FightPad's buttons and directional pad.
  1. Use tweezers to completely remove the sticker from the rear of controller.
    • Use tweezers to completely remove the sticker from the rear of controller.
  2. Find the seven 8.3 mm Phillips screws on the rear of the controller and remove them.
    • Find the seven 8.3 mm Phillips screws on the rear of the controller and remove them.
  3. Use a plastic opening tool to separate the rear and front casing by inserting it in-between the two cases. Use the plastic opening tool to pry the two cases apart.
    • Use a plastic opening tool to separate the rear and front casing by inserting it in-between the two cases.
    • Use the plastic opening tool to pry the two cases apart.
  4. Gratis verzending van alle bestellingen van meer dan US$ 100 of met een Pro Tech Toolkit!
    Doorblader onze winkel
  5. Remove the two rubber side grips. Remove the two rubber side grips.
    • Remove the two rubber side grips.
  6. Locate RS-DP-LS switch. Pull upwards on the switch to remove it.
    • Locate RS-DP-LS switch.
    • Pull upwards on the switch to remove it.
  7. Locate the four 8.3 mm Phillips screws on the circuit board and remove them.
    • Locate the four 8.3 mm Phillips screws on the circuit board and remove them.
  8. Hold the controller cable at the area just before it meets the controller and slowly lift upwards to slide it out of its plastic slot and remove the circuit board. Be careful with the wires connected to the circuit board itself as they are thin and delicate. When reassembling the controller, make sure that the bottom plastic piece is fully inserted into its slot before replacing the circuit board.
    • Hold the controller cable at the area just before it meets the controller and slowly lift upwards to slide it out of its plastic slot and remove the circuit board.
    • Be careful with the wires connected to the circuit board itself as they are thin and delicate.
    • When reassembling the controller, make sure that the bottom plastic piece is fully inserted into its slot before replacing the circuit board.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Jefferson Hsu
408 Reputatie
3 handleidingen geschreven
Cal Poly, Team 1-7, Propen Fall 2012 Lid van Cal Poly, Team 1-7, Propen Fall 2012
CPSU-PROPEN-F12S1G7
4 Leden
7 handleidingen geschreven
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 1
Afgelopen 30 Dagen: 5
Altijd: 1,674
