Ga door naar hoofdinhoud
Mad Catz Rock Band 4 Wireless Fender Sync Component Replacement
Wat je nodig hebt
  1. Mad Catz Rock Band 4 Wireless Fender Sync Component Replacement, Outer Casing: stap 1, afbeelding 1 van 1
    • Flip the guitar over so it is back side up. The battery compartment should be facing up.
    • Use a size J1 head screwdriver to remove the ten 5 mm short screws.
    • Use a J1 screwdriver to remove the four 5 mm long screws on the back of the device.
  2. Mad Catz Rock Band 4 Wireless Fender Sync Component Replacement: stap 2, afbeelding 1 van 1
    • Turn the device over so the front of the guitar is facing you.
    • Using a size J1 philips head screwdriver, remove the eleven 5 mm silver screws (circled in red) around the white panel.
  3. Mad Catz Rock Band 4 Wireless Fender Sync Component Replacement: stap 3, afbeelding 1 van 1
    • Gently lift the white panel and twist 90 degrees clockwise.
    • Using a size J1 head screwdriver, remove the two 5 mm black screws from underneath the white panel. You should now be able to pull the guitar apart.
  4. Mad Catz Rock Band 4 Wireless Fender Sync Component Replacement, Sync Component: stap 4, afbeelding 1 van 1
    • Remove the two black 5 mm screws (circled in red) from the back of the power button component using a size J1 philips head screwdriver. You can identify this by the code J5-B on the component.
    • Lift the small, rectangular circuit board out and set it aside.
  5. Mad Catz Rock Band 4 Wireless Fender Sync Component Replacement: stap 5, afbeelding 1 van 1
    • Locate the sync component hardware. It is a small circuit board that sits sideways with respect to the other circuit boards around it.
    • Remove the two 5mm black screws (circled in red) holding the circuit board in place using a size J1 philips head screwdriver. The component should now slide out vertically.
  6. Mad Catz Rock Band 4 Wireless Fender Sync Component Replacement: stap 6, afbeelding 1 van 1
    • Follow the wires connected to the sync component back to the main circuit board. Unplug the component from the main circuit board.
Conclusie
Hollynn Ricker
451 Reputatie
2 handleidingen geschreven
USF Tampa, Team 1-1, Cagle Fall 2016 Lid van USF Tampa, Team 1-1, Cagle Fall 2016
USFT-CAGLE-F16S1G1
4 Leden
6 handleidingen geschreven
Één opmerking
How do I replace the sync wire? Where can I purchase a new sync component?
Ange - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 27
Altijd: 2,271
