Ga door naar hoofdinhoud
Mad Catz Dual Force 2 Pro Analog Joystick Covers Replacement
Wat je nodig hebt
  1. Mad Catz Dual Force 2 Pro Analog Joystick Covers Replacement, Remove Cover: stap 1, afbeelding 1 van 1
    • Remove the six 7 mm Phillips screws from the rear cover.
  2. Mad Catz Dual Force 2 Pro Analog Joystick Covers Replacement: stap 2, afbeelding 1 van 1
    • Remove the back of the controller.
    • There are no loose items in the controller that can fall out, so you can open it, generally, however you want.
  3. Mad Catz Dual Force 2 Pro Analog Joystick Covers Replacement: stap 3, afbeelding 1 van 1
    • Remove the two 7 mm screws on the closest circuit board.
  4. Mad Catz Dual Force 2 Pro Analog Joystick Covers Replacement: stap 4, afbeelding 1 van 2 Mad Catz Dual Force 2 Pro Analog Joystick Covers Replacement: stap 4, afbeelding 2 van 2
    • Lift the closest circuit board away from the motherboard.
    • Be sure you do not tear the ribbon connecting the smaller circuit board to the motherboard.
  5. Mad Catz Dual Force 2 Pro Analog Joystick Covers Replacement: stap 5, afbeelding 1 van 1
    • Grip the analog stick you wish to remove and the smaller circuit board or the cover.
    • Pull the analog stick from the smaller circuit board.
Conclusie
Alexander Coyne
658 Reputatie
5 handleidingen geschreven
USF Tampa, Team 7-2, Remmell Winter 2015 Lid van USF Tampa, Team 7-2, Remmell Winter 2015
USFT-REMMELL-W15S7G2
4 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 16
Altijd: 618
