Ga door naar hoofdinhoud
Macintosh PowerBook 165c Daughterboard Replacement
Wat je nodig hebt
  1. Macintosh PowerBook 165c Daughterboard Replacement, Battery: stap 1, afbeelding 1 van 1
    • Orient the computer so the battery is facing you.
    • Slide the gray plastic battery cover to the right.
  2. Macintosh PowerBook 165c Daughterboard Replacement: stap 2, afbeelding 1 van 1
    • Pull the battery toward yourself until it is fully detached.
  3. Macintosh PowerBook 165c Daughterboard Replacement, Input/Output Door: stap 3, afbeelding 1 van 1
    • Orient the computer right side up with the rear facing you.
    • Open the Input/Output (I/O) door.
  4. Macintosh PowerBook 165c Daughterboard Replacement: stap 4, afbeelding 1 van 1
    • Carefully bend the door into an arch until one of the pins releases from its slot.
    • Once one of the pins is free, remove the I/O door from the computer.
  5. Macintosh PowerBook 165c Daughterboard Replacement, Lower Case: stap 5, afbeelding 1 van 1
    • Orient the computer with the bottom facing up and rear facing you. You should be able to read the Macintosh label in this position.
  6. Macintosh PowerBook 165c Daughterboard Replacement: stap 6, afbeelding 1 van 1
    • Use a T8 torx screwdriver to remove the 6.8mm long screw above and to the right of the modem jack.
    • Twist counter clockwise to remove the screw.
  7. Macintosh PowerBook 165c Daughterboard Replacement: stap 7, afbeelding 1 van 1
    • Use a T10 torx screwdriver to remove the four, 18mm long screws from the lower case.
  8. Macintosh PowerBook 165c Daughterboard Replacement: stap 8, afbeelding 1 van 2 Macintosh PowerBook 165c Daughterboard Replacement: stap 8, afbeelding 2 van 2
    • Place your hands on the lower case, just above the I/O panel, and slowly lift the lower case a few inches above the main body of the computer.
    • Release the large, gray interconnect ribbon cable just behind the I/O panel.
    • Caution: Lower case cannot be fully removed until two plastic clips in the front corners are released. See the following step for details.
  9. Macintosh PowerBook 165c Daughterboard Replacement: stap 9, afbeelding 1 van 2 Macintosh PowerBook 165c Daughterboard Replacement: stap 9, afbeelding 2 van 2
    • Place your thumb on the upper case, inside the empty battery slot, and your index finger near your thumb on the left side of the lower case.
    • Pinch your thumb and index finger towards each other to release the clip. Without releasing pressure on the pinch grip, use your index finger to push the lower case upwards.
    • Lift the lower case to remove it.
  10. Macintosh PowerBook 165c Daughterboard Replacement, RAM and PSRAM Expansion Card: stap 10, afbeelding 1 van 2 Macintosh PowerBook 165c Daughterboard Replacement, RAM and PSRAM Expansion Card: stap 10, afbeelding 2 van 2
    • Locate and lift ram card directly up until connector releases.
    • Move the card back and forth gently if the connector does not release immediately.
  11. Macintosh PowerBook 165c Daughterboard Replacement: stap 11, afbeelding 1 van 2 Macintosh PowerBook 165c Daughterboard Replacement: stap 11, afbeelding 2 van 2
    • Locate and lift the PSRAM expansion card vertically until connector releases.
    • If the PSRAM expansion card is difficult to remove, gently jostle it back and forth as you lift up.
    • The PSRAM expansion card is an optional component, and may not be included in all devices.
  12. Macintosh PowerBook 165c Daughterboard Replacement, Daughterboard: stap 12, afbeelding 1 van 1
    • Use T8 torx screwdriver to remove four, 7.7mm long screws from the perimeter of the daughterboard.
  13. Macintosh PowerBook 165c Daughterboard Replacement: stap 13, afbeelding 1 van 1
    • Life the daughterboard directly up to remove it from the connector.
    • If the daughterboard does not easily release from the connector, gently jostle it back and forth as you lift up.
Conclusie
Adam
1 Reputatie
4 handleidingen geschreven
Cal Poly, Team 6-3, Regan Fall 2011 Lid van Cal Poly, Team 6-3, Regan Fall 2011
CPSU-REGAN-F11S6G3
4 Leden
12 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 2
Altijd: 1,297
