Ga door naar hoofdinhoud
Macintosh PowerBook 1400 Series Keyboard Replacement
Wat je nodig hebt
  1. Macintosh PowerBook 1400 Series Keyboard Replacement, Battery: stap 1, afbeelding 1 van 1
    • Turn the device upside down and then locate the battery latch near the front of the device.
  2. Macintosh PowerBook 1400 Series Keyboard Replacement: stap 2, afbeelding 1 van 1
    • Slide the latch to the left to release the battery.
  3. Macintosh PowerBook 1400 Series Keyboard Replacement: stap 3, afbeelding 1 van 1
    • Continue holding the latch then gently pull the battery out of the device.
    • Place the battery in a safe location.
  4. Macintosh PowerBook 1400 Series Keyboard Replacement, CD-ROM Drive: stap 4, afbeelding 1 van 1
    • Locate the CD-ROM Drive latch.
  5. Macintosh PowerBook 1400 Series Keyboard Replacement: stap 5, afbeelding 1 van 1
    • Slide the latch to the right to release the CD ROM drive.
  6. Macintosh PowerBook 1400 Series Keyboard Replacement: stap 6, afbeelding 1 van 1
    • Continue holding the latch then gently pull the CD-ROM Drive out of the device.
    • Place the CD ROM drive in a safe location.
  7. Macintosh PowerBook 1400 Series Keyboard Replacement, Keyboard: stap 7, afbeelding 1 van 1
    • Locate the speaker cover.
  8. Macintosh PowerBook 1400 Series Keyboard Replacement: stap 8, afbeelding 1 van 1
    • Press firmly on each end of the speaker cover and slide it to the left.
  9. Macintosh PowerBook 1400 Series Keyboard Replacement: stap 9, afbeelding 1 van 1
    • Gently lift the speaker cover to remove it.
  10. Macintosh PowerBook 1400 Series Keyboard Replacement: stap 10, afbeelding 1 van 1
    • Lift the keyboard up from the back using a spudger(wedge side).
  11. Macintosh PowerBook 1400 Series Keyboard Replacement: stap 11, afbeelding 1 van 1
    • Gently lift the keyboard until only the ribbon cable remains attached.
  12. Macintosh PowerBook 1400 Series Keyboard Replacement: stap 12, afbeelding 1 van 1
    • Tilt the keyboard away from the screen.
  13. Macintosh PowerBook 1400 Series Keyboard Replacement: stap 13, afbeelding 1 van 1
    • Locate the six screws that secure the heatsink.
  14. Macintosh PowerBook 1400 Series Keyboard Replacement: stap 14, afbeelding 1 van 1
    • Remove the six screws from the heatsink using the Philips #1 screwdriver.
  15. Macintosh PowerBook 1400 Series Keyboard Replacement: stap 15, afbeelding 1 van 1
    • Lift the heatsink from the side closest to the laptop screen.
  16. Macintosh PowerBook 1400 Series Keyboard Replacement: stap 16, afbeelding 1 van 1
    • Remove the heatsink.
  17. Macintosh PowerBook 1400 Series Keyboard Replacement: stap 17, afbeelding 1 van 1
    • Gently pull up on the beige ribbon lock until it moves a short distance on both sides to separate the ribbon cable from the connector.
  18. Macintosh PowerBook 1400 Series Keyboard Replacement: stap 18, afbeelding 1 van 1
    • Detach the ribbon cable.
  19. Macintosh PowerBook 1400 Series Keyboard Replacement: stap 19, afbeelding 1 van 1
    • Remove the keyboard.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Sean Bent
41 Reputatie
1 Handleiding geschreven
Cal Poly, Team 10-39, Forte Spring 2011 Lid van Cal Poly, Team 10-39, Forte Spring 2011
CPSU-FORTE-S11S10G39
5 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 9
Altijd: 2,417
