Inleiding
This guide will show how to open up the PowerBook so that you may access the hard drive, and then show how to remove the hard drive.
Wat je nodig hebt
Turn the device upside down and then locate the battery latch near the front of the device.
Press firmly on each end of the speaker cover and slide it to the left.
I found it was easy to get a spudger over the left edge and lift it up a bit, then push the bar to the left, It pops right off after that.
Locate and identify the two screws that attach the hard drive to the computer.
Remove the hard drive from the computer by pushing down on the plastic strap and pulling up on the hard drive.
11 andere personen hebben deze handleiding voltooid.
Één opmerking
Hi iFixIt thanks for all the details BUT the keyboard can indeed stay in
when changing the hard drive. Just slide it a bit to the right after step
11, the ribbon cble does not take any damage. SO: from step 12 jump
straight to step 20. The heat sink can stay untouched, which i find not
unimportant to mention. Regards, TB75
