Ga door naar hoofdinhoud
Macintosh IIsi Hard Drive Replacement
Wat je nodig hebt
  1. Macintosh IIsi Hard Drive Replacement, Top Case: stap 1, afbeelding 1 van 2 Macintosh IIsi Hard Drive Replacement, Top Case: stap 1, afbeelding 2 van 2
    • Start by turning the computer around, and remove this #0 Phillips Screw.
    • There may or may not be a Phillips #0 screw here, depending on whether or not the computer has ever been serviced.
  2. Macintosh IIsi Hard Drive Replacement: stap 2, afbeelding 1 van 3 Macintosh IIsi Hard Drive Replacement: stap 2, afbeelding 2 van 3 Macintosh IIsi Hard Drive Replacement: stap 2, afbeelding 3 van 3
    • Now lift these two clips, and slowly pivot the case up.
    • You can now seperate the top of the computer from the rest of the machine.
  3. Macintosh IIsi Hard Drive Replacement, Hard Drive: stap 3, afbeelding 1 van 3 Macintosh IIsi Hard Drive Replacement, Hard Drive: stap 3, afbeelding 2 van 3 Macintosh IIsi Hard Drive Replacement, Hard Drive: stap 3, afbeelding 3 van 3
    • The Macintosh IIsi's hard drive is located ajacent to the ram and floppy drive.
    • Start by pushing these two tabs out, and lifting the drive up.
    • Then, flip the drive over, and remove the connection cables.
  4. Macintosh IIsi Hard Drive Replacement: stap 4, afbeelding 1 van 3 Macintosh IIsi Hard Drive Replacement: stap 4, afbeelding 2 van 3 Macintosh IIsi Hard Drive Replacement: stap 4, afbeelding 3 van 3
    • The hard drive: A Quantum ProDrive LPS, made in 1990, and surprisingly, it still works!
    • This drive has an 80MB capacity, not very large by today's standards, but not bad way back then...
    • Believe it or not, hard drive construction hasn't changed much in the last 20 years. Other than a few new interfaces, the form factor, 3.5" width and 4-Pin 12V/5V power connector has stayed the same.
    How can a read that SCSI HDD today if the computer does not boot? Any way to connect externally to a PC?
    Charles - Antwoord
Conclusie
4 andere personen hebben deze handleiding voltooid.
Chris Green
36.978 Reputatie
49 handleidingen geschreven
Master Techs Lid van Master Techs
Community
322 Leden
2.528 handleidingen geschreven
2 opmerkingen
Hello cano you please tell me how is the jumpering setting for a Quantum Prodrive LT 700MB
Juan - Antwoord
Is there a way to read the HDD on a PC?
Charles - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 7
Altijd: 3,950
