Ga door naar hoofdinhoud
MacPro fan removal
Wat je nodig hebt
  1. MacPro fan removal, MacPro fan removal: stap 1, afbeelding 1 van 1
    • You want to pull off the grey fan-assembly on the left (already gone in the pic), for that you have to unscrew 4 Screws in the memory-compartment on the right, slide that to the right and take out the middle cover for the processors
  2. MacPro fan removal: stap 2, afbeelding 1 van 1
    • The problem often is, that the slide-holder of the fan-assembly is quite stuck in the black plastic on the bottom of the case; it helps a lot to use a flat metal stick to push it up and out
    • The card-retaining blade that has two hand-driven screwheads is quite ideal for this purpose
Conclusie
4 andere personen hebben deze handleiding voltooid.
Dirk Winning
277 Reputatie
1 Handleiding geschreven
Één opmerking
I just completed a task on a Mac Pro 3,1, early 2008, A1186; I installed a pair of SSDs in the optical bay. This required running a pair of SATA cables from the motherboard to the optical bay, which in turn required removing the front fan assembly.
On this model, I didn’t have to do anything with the RAM cage. I removed the screw that fastens the fan assembly to the motherboard, and I removed the CPU cover (fastened with magnets — just pull and it comes off), Removing the CPU cover reveals another screw right at the corner between the heat sink and the fan assembly. After both screws are removed, the fan assembly comes off easily (it didn’t stick after I removed the screw).
According to comments, the next model Mac Pro has the cables already run to the optical bay. The question arises: does that model still have an IDE optical drive, or would we have to sacrifice the optical if we want to use both SATA cables in the optical bay?
Don Ellis - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 9
Altijd: 7,902
