Deze handleiding heeft recentere wijzigingen. Schakel over naar de nieuwste niet-geverifieerde versie.
Inleiding
Replacement of the upper case requires removal of most components in your MacBook.
Wat je nodig hebt
Remove the eight 4 mm Phillips screws securing the lower case to the MacBook.
Use the flat end of a spudger to lift the battery connector up out of its socket on the logic board.
Remove the following screws from the optical drive side of the rear vent:
Two 10 mm T8 Torx
Two 5.2 mm Phillips
Use the flat end of a spudger to pry the AirPort/Bluetooth ribbon cable up off the logic board.
Remove the two Phillips screws securing the hard drive bracket to the upper case.
Remove the hard drive bracket from the upper case.
Open your MacBook so the display is perpendicular to the upper case.
Place your opened MacBook on a table as pictured.
While holding the display and upper case together with your left hand, remove the remaining T8 Torx screw from the lower display bracket.
Before retightening the T8 Torx screws, close the display and adjust it so that the back edges of the upper case and display are aligned and the gaps at the ends of the hinge are equal.
There are four orange and black rubber inserts that the hard drive sit into. one side has full circles and the other side has half circles. ( The other side of the half circles are located on the hard drive bracket that was previously removed).
The new upper case may not have these inserts. e sure to remove them from the old and insert into the new.
The inserts are easily pried out with a spudger or a flat tipped screwdriver. They are not glued in, but instead have notched sides to hold them in place.
12 andere personen hebben deze handleiding voltooid.
