Inleiding
Rock out too hard? Use this guide to replace a blown-out rear speaker.
  1. Remove the eight 4 mm Phillips screws securing the lower case to the MacBook.
    • Remove the eight 4 mm Phillips screws securing the lower case to the MacBook.
  2. The lower case is constructed of rubber-coated aluminum. Do not excessively bend the aluminum during removal, as any permanent deformation will cause tolerance issues after reassembly. Slightly lift the lower case near the vent opening. Continue running your fingers between the lower and upper cases until the upper case pops off its retaining clips.
    • The lower case is constructed of rubber-coated aluminum. Do not excessively bend the aluminum during removal, as any permanent deformation will cause tolerance issues after reassembly.
    • Slightly lift the lower case near the vent opening.
    • Continue running your fingers between the lower and upper cases until the upper case pops off its retaining clips.
    • The location of these three clips is shown in the third picture.
  3. For precautionary purposes, we advise that you disconnect the battery connector from the logic board to avoid any electrical discharge. This step is optional and is not required.
    • For precautionary purposes, we advise that you disconnect the battery connector from the logic board to avoid any electrical discharge. This step is optional and is not required.
    • Use the flat end of a spudger to lift the battery connector up out of its socket on the logic board.
    • It may be easier to use your fingernails to lift up on both sides of the connector.
  4. Remove the following screws from the optical drive side of the rear vent:
    • Remove the following screws from the optical drive side of the rear vent:
      • Two 10 mm T8 Torx
      • Two 5.2 mm Phillips
  5. Remove the following screws from the port side of rear vent:
    • Remove the following screws from the port side of rear vent:
      • Two 10 mm T8 Torx
  6. Carefully lift the rear vent out of the upper case.
    • Carefully lift the rear vent out of the upper case.
  7. Gratis verzending van alle bestellingen van meer dan US$ 100,00 of met een Pro Tech Toolkit!
    Doorblader onze winkel
  8. Use the flat end of a spudger to pry the AirPort/Bluetooth cable connector up off the logic board.
    • Use the flat end of a spudger to pry the AirPort/Bluetooth cable connector up off the logic board.
  9. Remove the following screws securing the right speaker assembly to the upper case:
    • Remove the following screws securing the right speaker assembly to the upper case:
      • One 12 mm Phillips screw.
      • One 3 mm Phillips screw.
  10. Remove the single 2.2 mm Phillips screw inserted horizontally into the side of the optical drive.
    • Remove the single 2.2 mm Phillips screw inserted horizontally into the side of the optical drive.
  11. Pry the AirPort and Bluetooth antenna connectors (3 total) up off the AirPort/Bluetooth card. De-route the long antenna from its channel in the rear speaker housing.
    • Pry the AirPort and Bluetooth antenna connectors (3 total) up off the AirPort/Bluetooth card.
    • De-route the long antenna from its channel in the rear speaker housing.
  12. Use the flat end of a spudger to pry the rear speaker cable connector up off the logic board.
    • Use the flat end of a spudger to pry the rear speaker cable connector up off the logic board.
  13. Remove the rear speaker assembly from the upper case.
    • Remove the rear speaker assembly from the upper case.
  14. Carefully peel the AirPort/Bluetooth cable from its channel within the rear speaker assembly. Use the flat end of a spudger to pry the AirPort/Bluetooth cable up off the rear speaker.
    • Carefully peel the AirPort/Bluetooth cable from its channel within the rear speaker assembly.
    • Use the flat end of a spudger to pry the AirPort/Bluetooth cable up off the rear speaker.
  15. Remove three 3 mm Phillips screws securing the AirPort/Bluetooth board to the rear speaker assembly.
    • Remove three 3 mm Phillips screws securing the AirPort/Bluetooth board to the rear speaker assembly.
  16. Lift the AirPort/Bluetooth board up off the rear speaker assembly.
    • Lift the AirPort/Bluetooth board up off the rear speaker assembly.
  17. Rear speaker remains.
    • Rear speaker remains.
Conclusie
14 andere personen hebben deze handleiding voltooid.
Één commentaar
Nice tuto ! Helped me so fine.
Rudy Pierrat - Antwoord
Weergavestatistieken:
Afgelopen 24 Uren: 13
Afgelopen 7 Dagen: 37
Afgelopen 30 Dagen: 182
Altijd: 21,636
