Inleiding
This guide is an internal private guide used as a prereq.
Wat je nodig hebt
Use the flat end of a spudger to lift the battery connector up out of its socket on the logic board.
Één andere persoon heeft deze handleiding voltooid.
you do not need to remove the battery when replacing the hard drive or ram
brilldoctor - Antwoord
beware not to lift the connector to close of the angle, as the picture suggest it. It might broke the angle. Attack by the middle.
naamol - Antwoord
Not necessary?
hikkymemo - Antwoord
Be careful of the corner of the battery cable connector when trying to pry it off with the spudge. I knocked the corner of mine. No operational impact but was not very pleasing!
jljordanweb - Antwoord
Not necessary, but a good idea, so as to avoid any spurious charges going through the boards...
svenaustx - Antwoord
@Svenaustx - What could happen if not removing this battery? Worst case? Not a geek on this but did change RAM on my Macbook Pro "15. Can't remember disconneting the battery back then. Shouldn't it be sufficient shutting the Mac off and ensure it has been used for an hour or so before replacing RAM?
Allan Clarke -
i used a metal pry and noticed some sparking when i disconnected the battery. replaced ram. now it wont turn on. did i fry it?
Ian Lynch - Antwoord
