Inleiding
Use this guide to replace fatigue damaged antenna cables routed inside the display.
Wat je nodig hebt
Remove the eight 4 mm Phillips screws securing the lower case to the MacBook.
Slightly lift the lower case near the vent opening.
Continue running your fingers between the lower and upper cases until the upper case pops off its retaining clips.
Do the retaining clips have to be re-engaged when replacing the lower case?
Answering my own question, the clips re-engage when the lower case is correctly positioned. You can help them by gently pressing the lower case with your thumbs midway along the two short sides. When everything is correctly aligned the eight screw holes line up.
Rather than running your fingernail down the sides to free up the retaining clips, I found that using an old credit card, inserted about 1/4”, to run along the left and right side popped those end retaining clips right off with no problem. You may need to twist the card slightly when in the middle area to help pop those off.
Use the flat end of a spudger to lift the battery connector up out of its socket on the logic board.
you do not need to remove the battery when replacing the hard drive or ram
Be careful of the corner of the battery cable connector when trying to pry it off with the spudge. I knocked the corner of mine. No operational impact but was not very pleasing!
Not necessary, but a good idea, so as to avoid any spurious charges going through the boards...
@Svenaustx - What could happen if not removing this battery? Worst case? Not a geek on this but did change RAM on my Macbook Pro "15. Can't remember disconneting the battery back then. Shouldn't it be sufficient shutting the Mac off and ensure it has been used for an hour or so before replacing RAM?
Remove the following screws from the optical drive side of the rear vent:
Two 10 mm T8 Torx
Two 5.2 mm Phillips
I have a problem with the two middle screws
same here...
Remove the following screws from the port side of rear vent:
Two 10 mm T8 Torx
Two 5.2 mm Phillips
Carefully lift the rear vent out of the upper case.
you can actually stop disassembling now and try to replace it now. after removing two t6 screws it came off pretty easily
Good tip, thanks! I skipped ahead to step 17 and had no problem getting the magsafe board out from under the logic board and the new one installed. Saves a lot of work disconnecting connectors indicated as Fragile!
matt15 -
Thank You! Saved me an hour or so of work and a lot of stress!
I also did Step 6, then skipped to Step 17 & 18. Once I had the display data cable off, I could remove the 2 T6 Torx screws holding the MagSafe board on and remove it. You can reach under the logic board with the point of the spudger to work the cable out of the socket. Note how you maneuver the board out of the tight space so you can maneuver it back in. When you put the new MagSafe board in, plug in the cable first. If you bend the wires so the plug approaches the socket at the appropriate angle, you can nudge it in with the pointed end of the spudger.
Thanks a lot for this hint! You saved my macbook, when I failed to unscrew the fan because of one completely destroyed screw. Thanks to your comment I skipped steps 7-16 and went straight to replacing the magsafe board without problems. The spudger and some 3D imagination and done,
Remove the single 3 mm Phillips screw securing the AirPort/Bluetooth antenna ground strap to the rear speaker.
Gently pull the display data cable connector away from its socket on the logic board.
I have several of these machines in various states..mostly the logic boards need checking. I find that the clip for the LCD socket falls off and is almost impossible to reconnect, I think I may have fried some of the logic boards by pushing this connector in without that clip. Is that possible? Any tips? Like i was going to try to insert the LCD connector and place insulating tape to hold it in place..good or bad idea?
Insert the flat end of a spudger between the thin rubber strip surrounding the front display bezel and the rear display bezel.
Use the flat end of your spudger to carefully pry the front display bezel away from the adhesive securing it to the rear display bezel.
Continue prying until the front display bezel is free along the right side of the display and behind the right clutch hinge.
Remove the two 3 mm Phillips screws securing the clutch cover to the rear display bezel.
Remove following six screws securing the LCD to the rear display bezel:
Four 3.4 mm Phillips.
Two 3 mm Phillips.
Use the tip of a spudger to flip up the thin steel retaining clip securing the display data cable to its socket on the LCD.
Pull the display data cable straight away from its socket on the LCD.
Lift the LCD out of the display assembly and set it aside.
I've read where some people have struggled with reconnecting this cable during reassembly. I found it easier to wait to route the camera cable to the camera until after reconnecting the display data cable and putting the display in place. That way I could pull a little more of the display data cable through towards the display and it gave me more room to work.
Remove the two small pieces of black tape securing the antenna cables to the rear display bezel.
8 andere personen hebben deze handleiding voltooid.
Één opmerking
What is the trick to reattaching the antenna cables? They appear to be shaped like a hexagon and not circular, but still not able to press them down.
According to this page http://support.apple.com/kb/HT1651?viewl..., the 8 screws are not identical.
Can anybody tell me where each kind of screw is supposed to go?
Gregoire - Antwoord
They are all 100% Identical. You were probably looking at a different model, or Apple has entered the wrong information... Hey, It happens...
Owen Davies -
The screws on the Late 2009 are identical. The blue lock compound might make tightening some require a little more effort.
svenaustx - Antwoord
Can I replace it with a SATA 3 cable?
nm - Antwoord
A1342 macbook does not have the right controller to support sata III
Owen Davies -
hi, i just got back from the apple store and they are really keen for me to upgrade to a new laptop since my battery is old and the screen is cracked, so glad i found ifixit i would love to upgrade this puppy! gonna make it a real sleeper! styler hall wrote about sticking 16 gb of ram in his a 1342 ? is this a simply mather of ordering 3 4gb sticks ?aslo i currently have 4 gb and would like to upgrade to 8 ( or indeed 16) does that mean i need to buy all new sticks or can i continue to use the old one and stick a new one next to it ?
thanks again mick van aar, perth western aus.
michelvanaar - Antwoord
The A1342 will take up to 16 GB of RAM, however, there are only two RAM slots, so use two 8-GB RAM modules. Other World Computing (OWC) is a great reference source for info on exactly which RAM to use with which model; prices are usually much better on EBay though. Add an SSD from OWC and your machine will really scream!
I hope that helps!
gdesbrisay -
Gregoire is right. The 8 screws are absolutely NOT identical, I’m looking at them right now, weeowey weeowey.
John Guzman - Antwoord
I just wanted to say that, in 2020, i used these instructions to replace the magsafe socket on my A1286, mid-2012, pre-Retina MacBook Pro. The internal layout is not quite the same but close enough for me to do the job. I skipped the steps of fully disconnecting the fans and speakers because of what others had said about breaking the sockets. it just meant I had to be extremely careful when lifting up the main board so that I did not tear and break the connections. I was able to disconnect the old magsafe socket with the board flat and in situ, but there was no where near enough room to be able to aline and press home the new par home. Reluctantly i had to lever up the board. This was difficult as there is a tapped post that holds a screw in the way close to where the USB sockets are, that prevented the board lifting up and out. I had to be quite forceful to manouevre the sockets out from the edge of the case.
Paul Burridge - Antwoord
