Ga door naar hoofdinhoud
MacBook Unibody Model A1278 Left Speaker Replacement
Wat je nodig hebt
  1. MacBook Unibody Model A1278 Left Speaker Replacement, Access Door: stap 1, afbeelding 1 van 1
    • With the case closed, place the Unibody top-side down on a flat surface.
    • Depress the grooved side of the access door release latch enough to grab the free end. Lift the release latch until it is vertical.
  2. MacBook Unibody Model A1278 Left Speaker Replacement: stap 2, afbeelding 1 van 1
    • The access door should now be raised enough to lift it up and out of the Unibody.
  3. MacBook Unibody Model A1278 Left Speaker Replacement, Battery: stap 3, afbeelding 1 van 1
    • Be sure the access door release latch is vertical before proceeding.
    • Grab the white plastic tab and pull the battery up and out of the Unibody.
  4. MacBook Unibody Model A1278 Left Speaker Replacement, Lower Case: stap 4, afbeelding 1 van 1
    • Remove the following eight screws securing the lower case to the chassis:
    • One 3 mm Phillips screw.
    • Four 3.5 mm Phillips screws.
  5. MacBook Unibody Model A1278 Left Speaker Replacement: stap 5, afbeelding 1 van 1
    • Using both hands, lift and remove the lower case off the upper case.
  6. MacBook Unibody Model A1278 Left Speaker Replacement, Mid Wall: stap 6, afbeelding 1 van 1
    • Remove the four 10.3 mm Phillips screws securing the mid wall to the upper case.
  7. MacBook Unibody Model A1278 Left Speaker Replacement: stap 7, afbeelding 1 van 1
    • Lift the mid wall out of the upper case.
  8. MacBook Unibody Model A1278 Left Speaker Replacement, Fan: stap 8, afbeelding 1 van 3 MacBook Unibody Model A1278 Left Speaker Replacement, Fan: stap 8, afbeelding 2 van 3 MacBook Unibody Model A1278 Left Speaker Replacement, Fan: stap 8, afbeelding 3 van 3
    • Use a spudger to pry the fan connector straight up off the logic board.
    • It is useful to twist the spudger axially from beneath the fan cable wires to release the connector.
    • The fan socket and the fan connector can be seen in the second and third pictures. Be careful not to break the plastic fan socket off the logic board as you use your spudger to lift the fan connector straight up and out of its socket. The layout of the logic board shown in the second picture may look slightly different than your machine but the fan socket is the same.
  9. MacBook Unibody Model A1278 Left Speaker Replacement: stap 9, afbeelding 1 van 1
    • Remove the following three screws securing the fan to the upper case:
    • Two 5 mm Phillips screws.
    • One 7 mm Phillips screw.
    • The longer of the three screws belongs in the upper left corner of the fan.
  10. MacBook Unibody Model A1278 Left Speaker Replacement: stap 10, afbeelding 1 van 1
    • Lift the fan out of the upper case.
  11. MacBook Unibody Model A1278 Left Speaker Replacement, Logic Board: stap 11, afbeelding 1 van 1
    • In the next few steps, you will disconnect the highlighted cables which connect the logic board to the upper case.
    • Each connector is different, so the following steps will show you how disconnect each in detail.
  12. MacBook Unibody Model A1278 Left Speaker Replacement: stap 12, afbeelding 1 van 2 MacBook Unibody Model A1278 Left Speaker Replacement: stap 12, afbeelding 2 van 2
    • Remove the single Phillips screw securing the battery cable cover to the upper case.
    • Remove the battery cable cover from the upper case.
  13. MacBook Unibody Model A1278 Left Speaker Replacement: stap 13, afbeelding 1 van 1
    • Use a spudger to pry the battery level indicator cable connector straight up off the logic board.
  14. MacBook Unibody Model A1278 Left Speaker Replacement: stap 14, afbeelding 1 van 1
    • Disconnect the battery cable connector by pulling it straight away from the logic board.
    • If you cannot grasp the cable with your fingers, a spudger and tweezers may be helpful for removal.
  15. MacBook Unibody Model A1278 Left Speaker Replacement: stap 15, afbeelding 1 van 3 MacBook Unibody Model A1278 Left Speaker Replacement: stap 15, afbeelding 2 van 3 MacBook Unibody Model A1278 Left Speaker Replacement: stap 15, afbeelding 3 van 3
    • Using the tip of a spudger, flip up the keyboard ribbon cable retaining flap.
    • Pull the keyboard ribbon cable straight out of its socket.
    • If the smaller connector at the right side of the keyboard ribbon cable is populated by another small black ribbon cable, remove it in a similar way to the above.
  16. MacBook Unibody Model A1278 Left Speaker Replacement: stap 16, afbeelding 1 van 1
    • Use the flat end of a spudger to pry the trackpad connector straight up off the logic board.
  17. MacBook Unibody Model A1278 Left Speaker Replacement: stap 17, afbeelding 1 van 2 MacBook Unibody Model A1278 Left Speaker Replacement: stap 17, afbeelding 2 van 2
    • Use the tip of a spudger to flip up the locking lever to release the IR sensor ribbon cable from its socket.
    • Use the tip of a spudger to pull the IR sensor ribbon cable straight away from the logic board.
  18. MacBook Unibody Model A1278 Left Speaker Replacement: stap 18, afbeelding 1 van 1
    • Use the flat end of a spudger to pry the hard drive cable connector straight up off the logic board.
  19. MacBook Unibody Model A1278 Left Speaker Replacement: stap 19, afbeelding 1 van 1
    • Use the flat end of a spudger to pry the optical drive cable connector straight up off the logic board.
  20. MacBook Unibody Model A1278 Left Speaker Replacement: stap 20, afbeelding 1 van 1
    • Disconnect the display data cable by pulling the male end straight away from its socket.
  21. MacBook Unibody Model A1278 Left Speaker Replacement: stap 21, afbeelding 1 van 1
    • Use the flat end of a spudger to pry the subwoofer cable connector straight up off the logic board.
  22. MacBook Unibody Model A1278 Left Speaker Replacement: stap 22, afbeelding 1 van 2 MacBook Unibody Model A1278 Left Speaker Replacement: stap 22, afbeelding 2 van 2
    • Grab the plastic pull tab secured to the display data cable lock and rotate it toward the DC-in side of the computer.
    • Pull the display data cable connector straight away from its socket.
  23. MacBook Unibody Model A1278 Left Speaker Replacement: stap 23, afbeelding 1 van 2 MacBook Unibody Model A1278 Left Speaker Replacement: stap 23, afbeelding 2 van 2
    • Remove the following two screws securing the display data cable bracket to the upper case:
    • One 7mm Phillips screw.
    • One 5mm Phillips screw.
    • Remove the two 7 mm Phillips screws from the DC-in board.
    • Lift the display data cable bracket out of the upper case.
  24. MacBook Unibody Model A1278 Left Speaker Replacement: stap 24, afbeelding 1 van 2 MacBook Unibody Model A1278 Left Speaker Replacement: stap 24, afbeelding 2 van 2
    • If present, remove the two 4mm Phillips screws securing the bottom case clip to the upper case.
    • Lift the bottom case clip out of the upper case.
  25. MacBook Unibody Model A1278 Left Speaker Replacement: stap 25, afbeelding 1 van 2 MacBook Unibody Model A1278 Left Speaker Replacement: stap 25, afbeelding 2 van 2
    • Remove the two 5mm Phillips screws securing the keyboard flex bracket to the upper case.
    • Lift the keyboard flex bracket out of the upper case.
  26. MacBook Unibody Model A1278 Left Speaker Replacement: stap 26, afbeelding 1 van 1
    • Use the tip of a spudger to release the microphone from the upper case.
  27. MacBook Unibody Model A1278 Left Speaker Replacement: stap 27, afbeelding 1 van 2 MacBook Unibody Model A1278 Left Speaker Replacement: stap 27, afbeelding 2 van 2
    • Remove the following five screws securing the logic board to the upper case:
    • Four 3mm Phillips screws.
    • One 3.5mm Phillips screw.
    • Lift the logic board from its left edge and pull it out of the upper case.
  28. MacBook Unibody Model A1278 Left Speaker Replacement, Microphone: stap 28, afbeelding 1 van 1
    • Deroute the microphone cable from the channel in the left speaker.
  29. MacBook Unibody Model A1278 Left Speaker Replacement: stap 29, afbeelding 1 van 1
    • Use the flat end of a spudger to pry the microphone cable connector up off the logic board.
  30. MacBook Unibody Model A1278 Left Speaker Replacement, Left Speaker: stap 30, afbeelding 1 van 1
    • Use the flat end of a spudger to pry the left speaker connector up off the logic board.
  31. MacBook Unibody Model A1278 Left Speaker Replacement: stap 31, afbeelding 1 van 1
    • Use the flat end of a spudger to separate the left speaker assembly from the adhesive securing it to the logic board.
Conclusie
12 andere personen hebben deze handleiding voltooid.
Één opmerking
Is this speaker the one responsible for the startup sound?
mo ali - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 41
Altijd: 21,877
