Inleiding
Replacing the hard drive on a Unibody is simple - it only requires removing one screw!
Wat je nodig hebt
With the case closed, place the Unibody top-side down on a flat surface.
Depress the grooved side of the access door release latch enough to grab the free end. Lift the release latch until it is vertical.
Remove the single Phillips screw securing the hard drive bracket to the upper case.
Bijna klaar!
Conclusie
