Ga door naar hoofdinhoud
MacBook Unibody Model A1278 Feet Replacement
Wat je nodig hebt
  1. MacBook Unibody Model A1278 Feet Replacement, Access Door: stap 1, afbeelding 1 van 1
    • With the case closed, place the Unibody top-side down on a flat surface.
    • Depress the grooved side of the access door release latch enough to grab the free end. Lift the release latch until it is vertical.
  2. MacBook Unibody Model A1278 Feet Replacement: stap 2, afbeelding 1 van 1
    • The access door should now be raised enough to lift it up and out of the Unibody.
  3. MacBook Unibody Model A1278 Feet Replacement, Battery: stap 3, afbeelding 1 van 1
    • Be sure the access door release latch is vertical before proceeding.
    • Grab the white plastic tab and pull the battery up and out of the Unibody.
  4. MacBook Unibody Model A1278 Feet Replacement, Lower Case: stap 4, afbeelding 1 van 1
    • Remove the following eight screws securing the lower case to the chassis:
    • One 3 mm Phillips screw.
    • Four 3.5 mm Phillips screws.
  5. MacBook Unibody Model A1278 Feet Replacement: stap 5, afbeelding 1 van 1
    • Using both hands, lift and remove the lower case off the upper case.
  6. MacBook Unibody Model A1278 Feet Replacement, Feet: stap 6, afbeelding 1 van 3 MacBook Unibody Model A1278 Feet Replacement, Feet: stap 6, afbeelding 2 van 3 MacBook Unibody Model A1278 Feet Replacement, Feet: stap 6, afbeelding 3 van 3
    • Remove any broken or damaged feet.
    • Remove any pieces from the old foot that may have broken off in the foot hole.
    • Use tweezers to peel up and remove the old adhesive tape from the foot pad.
  7. MacBook Unibody Model A1278 Feet Replacement: stap 7, afbeelding 1 van 1
    • Scrub the foot pad with adhesive remover to remove any remaining adhesive.
  8. MacBook Unibody Model A1278 Feet Replacement: stap 8, afbeelding 1 van 1
    • Wipe the foot pad with an alcohol prep pad to remove any residue left by the cleaner.
  9. MacBook Unibody Model A1278 Feet Replacement: stap 9, afbeelding 1 van 1
    • Peel a replacement foot from the plastic backing.
  10. MacBook Unibody Model A1278 Feet Replacement: stap 10, afbeelding 1 van 3 MacBook Unibody Model A1278 Feet Replacement: stap 10, afbeelding 2 van 3 MacBook Unibody Model A1278 Feet Replacement: stap 10, afbeelding 3 van 3
    • Align the new foot inside the foot pad.
    • Make sure the alignment nub on the foot is lined up with the small hole near the perimeter of the pad.
    • Lay the foot down while keeping it properly aligned.
    • Check for proper alignment from the inside of the lower case. Use tweezers to slide the alignment nub so it lines up with the hole.
  11. MacBook Unibody Model A1278 Feet Replacement: stap 11, afbeelding 1 van 1
    • Press the new foot down firmly with your finger and maintain pressure for 30 seconds to set the pressure sensitive adhesive. Support the other side of the cover while you press the foot down.
    • Repeat the last six steps for any broken or damaged feet.
Conclusie
6 andere personen hebben deze handleiding voltooid.
Adam O'Camb
196.326 Reputatie
416 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 22
Altijd: 2,697
