Inleiding
Use this guide to replace the DC-in board on your MacBook Pro.
Gereedschap
Onderdelen
Remove the following ten screws securing the lower case to the upper case:
Three 13.5 mm Phillips screws.
Seven 3 mm Phillips screws.
If present, grab the plastic tab attached to the battery connector and pull it toward the front edge of the device. For Late-2011 models the battery connector will not have a tab and is simply a plug that inserts straight down into the motherboard--to remove pry the plug straight up.
Use the flat end of a spudger to lift the right fan connector out of its socket on the logic board.
Use the flat end of a spudger to lift the left fan connector out of its socket on the logic board.
Pull the DC-In board connector away from its socket on the logic board.
26 andere personen hebben deze handleiding voltooid.
9 Opmerkingen
I have a late 2011 Macbook Pro. Any changes to this procedure before I take it apart? Thanks.
Hello, I have a macbook pro 17 " late 2017. Can the 820-2565-A flex cable be used as a replacement for the flex cable 820-2361-A? Thank you
Hi, I got a macbook pro unibody early 2009, A1297. The DC in board should be a 820-2361-A but it don´t deliver to sweden. Got a 820-2565-A, which is for MacBook Pro 17" Unibody (Mid 2010/Late 2011). Size same and looks same. Can I chuck it in ? anyone with experience ?
Have a sweet day !
Is there a symptom checklist for diagnosis anywhere?
