Gereedschap
Onderdelen
Geen onderdelen opgegeven.
Deze stap is niet vertaald. Help het te vertalen
Use the flat end of a spudger to lift the left fan connector out of its socket on the logic board.
Remove the three 3.1 mm Phillips screws securing the left fan to the logic board.
Remove the left fan from the upper case, minding its cable that may get caught.
Use the tip of a spudger or your fingernail to flip up the retaining flap on the keyboard backlight ribbon cable.
Pull the keyboard backlight ribbon cable out of its socket.
Use the tip of a spudger to push the small plastic cable retainer away from the camera cable socket for enough clearance to remove the camera cable.
Pull the camera cable toward the optical drive opening to disconnect it from the logic board.
Use the flat end of a spudger to pry the optical drive connector up and out of its socket on the logic board.
Use the flat end of a spudger to lift the subwoofer & right speaker connector out of its socket on the logic board.
Use the tip of a spudger or your fingernail to flip up the retaining flap on the IR sensor ribbon cable socket.
Pull the IR sensor ribbon cable out of its socket.
Remove the following four screws:
Two 3.5 mm Phillips screws
Two 1.6 mm Phillips screws
Remove both connector shields from the logic board.
Use the flat end of a spudger to pry the trackpad connector up and out of its socket on the logic board.
Use your fingernail to flip up the retaining flap on the keyboard ribbon cable socket.
Pull the keyboard ribbon cable out of its socket.
Use your fingernail to flip up the retaining flap on the express card cage ribbon cable socket.
Pull the express card cage ribbon cable out of its socket.
Use the flat end of a spudger to lift the hard drive cable connector up and out of its socket on the logic board.
Use the tip of a spudger or your fingernail to flip up the retaining flap on the battery indicator cable socket.
Pull the battery indicator ribbon cable out of its socket.
Lift the black plastic flap attached to the display data cable retainer and rotate it toward the DC-In side of the MacBook.
Pull the display data cable out of its socket.
Remove the following eight screws securing the logic board and DC-In board to the upper case:
Six 3.2 mm Phillips screws
Two 7.6 mm Phillips screws
Lift the logic board assembly from the side nearest the optical drive and lift it away from the upper case.
Carefully pull the ports and DC-In board away from the side of the upper case and remove the logic board assembly, minding any cables that may get caught.
