Ga door naar hoofdinhoud
MacBook Pro 17" Unibody Hard Drive Bracket Replacement
Wat je nodig hebt
  1. MacBook Pro 17" Unibody Hard Drive Bracket Replacement, Lower Case: stap 1, afbeelding 1 van 1
    • Seven 3 mm Phillips screws.
  2. MacBook Pro 17" Unibody Hard Drive Bracket Replacement: stap 2, afbeelding 1 van 2 MacBook Pro 17" Unibody Hard Drive Bracket Replacement: stap 2, afbeelding 2 van 2
    • Wedge your fingers between the lower case and the vent, and lift upward to release the two clips holding the lower case to the upper case.
    • During reassembly, carefully align the lower case and then press it firmly until both clips engage.
    • Remove the lower case.
  3. MacBook Pro 17" Unibody Hard Drive Bracket Replacement, Battery: stap 3, afbeelding 1 van 3 MacBook Pro 17" Unibody Hard Drive Bracket Replacement, Battery: stap 3, afbeelding 2 van 3 MacBook Pro 17" Unibody Hard Drive Bracket Replacement, Battery: stap 3, afbeelding 3 van 3
    • Whenever working near the logic board, it is always wise to first disconnect the battery to avoid short circuits.
    • If present, grab the plastic tab attached to the battery connector and pull it toward the front edge of the device. For Late-2011 models the battery connector will not have a tab and is simply a plug that inserts straight down into the motherboard--to remove pry the plug straight up.
    • If the plastic tab is missing, use a spudger to pry the connector up from its socket.
    • Pull the tab parallel to the face of the logic board.
  4. MacBook Pro 17" Unibody Hard Drive Bracket Replacement, Hard Drive: stap 4, afbeelding 1 van 1
    • Remove the two Phillips screws securing the hard drive bracket to the upper case.
    • These screws are captive to the hard drive bracket.
  5. MacBook Pro 17" Unibody Hard Drive Bracket Replacement: stap 5, afbeelding 1 van 1
    • Remove the hard drive bracket from the upper case.
  6. MacBook Pro 17" Unibody Hard Drive Bracket Replacement: stap 6, afbeelding 1 van 1
    • Use the hard drive's pull tab to lift it out of the upper case.
    • Don't try to completely remove the hard drive just yet! Its cable is still connected.
  7. MacBook Pro 17" Unibody Hard Drive Bracket Replacement: stap 7, afbeelding 1 van 2 MacBook Pro 17" Unibody Hard Drive Bracket Replacement: stap 7, afbeelding 2 van 2
    • Pull the hard drive connector away from the body of the hard drive.
    • Remove the hard drive from your MacBook Pro.
  8. MacBook Pro 17" Unibody Hard Drive Bracket Replacement, Hard Drive Bracket: stap 8, afbeelding 1 van 1
    • Remove the two 5 mm Phillips #00 screws securing the hard drive bracket to the upper case.
  9. MacBook Pro 17" Unibody Hard Drive Bracket Replacement: stap 9, afbeelding 1 van 3 MacBook Pro 17" Unibody Hard Drive Bracket Replacement: stap 9, afbeelding 2 van 3 MacBook Pro 17" Unibody Hard Drive Bracket Replacement: stap 9, afbeelding 3 van 3
    • Tilt the outer hard drive bracket up toward the logic board and remove it from the rear case.
Conclusie
10 andere personen hebben deze handleiding voltooid.
Sam Goldheart
457.097 Reputatie
537 handleidingen geschreven
iFixit Lid van iFixit
Community
139 Leden
16.880 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 24
Altijd: 4,385
