Inleiding
Replacing a defective fan is pretty easy and will keep your laptop running cool.
Wat je nodig hebt
Use your fingers to push both battery release tabs away from the battery and lift the battery out of the computer.
Remove the four identical Phillips 3.4 mm screws from the memory door. These screws have 4 mm diameter heads rather than the 3 mm heads on the body screws.
Remove the three Phillips screws in the battery compartment near the latch. Apple was nice enough to tilt these screws at a slight angle to make them easier to remove. On the A1261 these screws have 4 mm diameter heads rather than the 3 mm heads on the body screws.
Disconnect the display data cable and right fan cable from the logic board.
82 andere personen hebben deze handleiding voltooid.
3 opmerkingen
-thanks for the tips and prompt delivery to Canada from ifixit.com...took me 5 minutes. Use a tweezer with one hand as I did in the video ( http://goo.gl/3EZ5N5)
-recommend placing he mac on a soft towel to prevent scratches.
-Use precision screwdrivers (http://goo.gl/qRK4IF)
-use a compressed air canister to clean surrounding areas
Works like a charm now...
