Ga door naar hoofdinhoud
MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Battery Connector Replacement
Wat je nodig hebt
    1. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Battery Connector Replacement, Battery: stap 1, afbeelding 1 van 1
      • Use your fingers to push both battery release tabs away from the battery and lift the battery out of the computer.
      Vraag FixBot
      Voeg opmerking toe
    1. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Battery Connector Replacement, RAM Shield: stap 2, afbeelding 1 van 1
      • Remove the four identical Phillips 3.4 mm screws from the memory door. These screws have 4 mm diameter heads rather than the 3 mm heads on the body screws.
      Vraag FixBot
      Voeg opmerking toe
    2. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Battery Connector Replacement: stap 3, afbeelding 1 van 1
      • Lift the memory door up enough to get a grip on it, and slide it toward you, pulling it away from the casing.
      Vraag FixBot
      Voeg opmerking toe
    1. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Battery Connector Replacement, Upper Case: stap 4, afbeelding 1 van 1
      • Remove the three Phillips screws in the battery compartment near the latch. Apple was nice enough to tilt these screws at a slight angle to make them easier to remove. On the A1261 these screws have 4 mm diameter heads rather than the 3 mm heads on the body screws.
      Vraag FixBot
      Voeg opmerking toe
    2. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Battery Connector Replacement: stap 5, afbeelding 1 van 1
      • Remove the following six screws:
      • Two 14.5 mm T6 Torx screws on either side of the RAM slot.
      • Four 3.4 mm Phillips screws along the hinge.
      Vraag FixBot
      Voeg opmerking toe
    3. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Battery Connector Replacement: stap 6, afbeelding 1 van 1
      • Remove the four 3.4 mm Phillips screws on the port side of the computer.
      Vraag FixBot
      Voeg opmerking toe
    4. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Battery Connector Replacement: stap 7, afbeelding 1 van 1
      • Rotate the computer 90 degrees and remove the two Phillips screws from the rear of the computer.
      Vraag FixBot
      Voeg opmerking toe
    5. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Battery Connector Replacement: stap 8, afbeelding 1 van 1
      • Rotate the computer 90 degrees again and remove the four Phillips screws from the side of the computer.
      Vraag FixBot
      Voeg opmerking toe
    6. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Battery Connector Replacement: stap 9, afbeelding 1 van 1
      • Do not yank the upper case off quickly. The case is attached to the logic board via a ribbon cable.
      • Lift up the back of the case and work your fingers along the sides, freeing the case as you go. Once you have freed the sides, you may need to rock the case up and down to free the front of the upper case.
      Vraag FixBot
      Voeg opmerking toe
    7. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Battery Connector Replacement: stap 10, afbeelding 1 van 1
      • Disconnect the trackpad and keyboard ribbon cable from the logic board.
      • Remove the upper case.
      Vraag FixBot
      Voeg opmerking toe
    1. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Battery Connector Replacement, Optical Drive: stap 11, afbeelding 1 van 1
      • Disconnect the orange SuperDrive ribbon cable from the logic board, removing tape as necessary.
      Vraag FixBot
      Voeg opmerking toe
    2. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Battery Connector Replacement: stap 12, afbeelding 1 van 1
      • Remove the following three screws:
      • Two black 4 mm T6 Torx screws on either side of the SuperDrive.
      • One 8.7 mm silver (black in some models) T6 Torx screw at the back of the drive near the speaker.
      Vraag FixBot
      Voeg opmerking toe
    3. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Battery Connector Replacement: stap 13, afbeelding 1 van 1
      • Use one hand to pull back the speaker cable and use your other hand to lift the optical drive up and out of the computer.
      • If you have a CD or any other object jammed in your optical drive, we have an optical drive repair guide.
      Vraag FixBot
      Voeg opmerking toe
    1. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Battery Connector Replacement, Logic Board: stap 14, afbeelding 1 van 3 MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Battery Connector Replacement, Logic Board: stap 14, afbeelding 2 van 3 MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Battery Connector Replacement, Logic Board: stap 14, afbeelding 3 van 3
      • Disconnect the ten indicated connectors from the logic board.
      • The connectors have different positions for the four MacBook Pro revisions covered by this guide, and their locations are highlighted in the three pictures on this step.
      Vraag FixBot
      Voeg opmerking toe
    2. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Battery Connector Replacement: stap 15, afbeelding 1 van 1
      • Rotate the large display data cable to the left and disconnect the small right thermal sensor cable beneath.
      • If you have the A1261 model, the right thermal sensor cable is located in between the right fan connector and display data cable.
      Vraag FixBot
      Voeg opmerking toe
    3. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Battery Connector Replacement: stap 16, afbeelding 1 van 1
      • Remove the single black 4 mm T6 Torx screw securing the clear plastic shield over the right ambient light sensor.
      • Lift the clear plastic shield off the right ambient light sensor.
      Vraag FixBot
      Voeg opmerking toe
    4. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Battery Connector Replacement: stap 17, afbeelding 1 van 1
      • Peel up the orange Kapton tape securing the left thermal sensor cable to the logic board.
      • If you have a MacBook Pro 17" Model A1229, this is the middle thermal sensor.
      Vraag FixBot
      Voeg opmerking toe
    5. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Battery Connector Replacement: stap 18, afbeelding 1 van 1
      • Remove the following twelve screws:
      • Seven 6.5 mm T6 Torx screws.
      • Two shanked 7.6 mm T6 Torx screws securing the battery connector to the lower case.
      • Three 7.8 mm T6 Torx screws.
      Vraag FixBot
      Voeg opmerking toe
    6. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Battery Connector Replacement: stap 19, afbeelding 1 van 1
      • Lift up the left side of the logic board and disconnect the multi-colored power connector from the bottom of the board.
      Vraag FixBot
      Voeg opmerking toe
    7. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Battery Connector Replacement: stap 20, afbeelding 1 van 1
      • Grasp the logic board at the left side and at the thin section near the right fan, and rotate the logic board out of the lower case.
      Vraag FixBot
      Voeg opmerking toe
    8. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Battery Connector Replacement: stap 21, afbeelding 1 van 1
      • If the right speaker assembly remains attached to the logic board, hold the logic board with one hand and slide the speaker up slightly to free it from the logic board.
      • To properly reassemble your MacBook Pro, you'll have to clean off and replace the thermal compound from the three chips on the underside of the logic board. Use our Applying Thermal Paste Guide to prepare the processor and heat sink surfaces.
      Vraag FixBot
      Voeg opmerking toe
    1. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Battery Connector Replacement, Battery Connector: stap 22, afbeelding 1 van 1
      • Disconnect the multi-colored battery connector from the logic board.
      • To properly reassemble your MacBook Pro, you'll have to clean off and replace the thermal compound from the three chips shown here. Use our Applying Thermal Paste Guide to prepare the processor and heat sink surfaces.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
4 andere personen hebben deze handleiding voltooid.
iRobot
1 Reputatie
635 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 68
Altijd: 15,274
